GM 12 bolt Rebuild
I'm getting ready to buy the parts to rebuild my rear end for my 67 c10 but I am unsure which posi unit to buy.
I want to run a Eaton Posi and 3.73 Richmond Gears but am not sure if it should be a 3 or 4 series carrier. Eaton Posi Part Number ???? Richmond 3.73 Gears Part Number ???? Richmond Gear Differential Complete Kit 8.875" 12 Bolt part number 83-1018-1 |
![]() Join Date: Nov 2013
Re: GM 12 bolt Rebuild
Go here and run the Diff Wizard...it will give you the part numbers....then look at Jeg's or Summit for a better price...
https://www.randysworldwide.com/
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Its a Truck Thing......
I have rebuilt several 12 bolts and more on the future and unless you have a great history with Richmond Gears I would choose another brand. Lots of issues on the web and I ran into gear noise myself. 3.73 gears (regular) run a series 4 carrier.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#4 | |
He bought all the parts with the Richmond gear set and I installed it for him...it was a 3.08 and it went in perfectly.... I set the pinion depth to the dimension etched on the end and it patterned perfectly.... ran it in for a few minutes off the ground and drove it off...quiet as can be..... again this was my first experience with Richmond...not plugging them.....just my 2¢
I have no real experience with Richmond. What would you recommend?
I installed a set into a 12 bolt and from opening the box I started questioning the product. The compound markings from the factory were way more towards the toe side than I set up (not a racing application). I did get it exactly as they sent it with the BL at .008 that was scribbled on the gear set. All new bearings went in also. Started out great, no noise, broke it in all was good. After about 25 miles on it started getting noise on decel. Tore it apart and the outer pinion race grenaded itself. Replaced all bearings with Timken's and started making more noises and they were not consistent at all not same RPM's, speeds or gear selections.. Tore back apart, Timken's were perfect. Started digging and found that the gears are made in India and they are making them with a harder material and that they can make noise. Read a bunch of threads and found professionals with the same issues. Now I am not bashing Richmond Gears at all. The set I installed has over 2K on them and the guy is happy with it and drove it on a 1600 mile trip from AZ to TN with zero problems. I hate gear noises and that would drive me crazy driving it.
For me, I have used Motive Gears and I use Open Carriers and have had no problems or noises. I suggest doing a lot of research on the gear set you want to install and make phone calls to get to your comfort level. It is a lot of money to get an axle rebuilt and you want to ensure that it is to your satisfaction. Try looking at US Gear and TomsDifferentials. Lastly, Is the original poster installing the gears or having them installed? Smitty
#7 | |
Yukon makes a good ring and pinion, easy to set up a good pattern and quiet. Always my first choice for a driven vehicle. I usually still go with Richmond in a car /truck that's raced. Be careful with a lot most of these companies are selling two different grade gears. Regular ones and a cheaper imported set.
Yukons install kits always come with Timken bearings and races.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
#9 | |
I`ve never used one, I usually go with Eaton Differentials. Posi`s or their true tracs. True tracs are stronger and less expensive. I have an Auburn in my truck because I had a big credit with a company and saved a lot of cash. Been low 12`s with a good tire at over 4900 lbs, still holding up.
![]() Join Date: Apr 2015
The Yukon is the one I went with. Basically a Eaton clone. Yukon makes quality stuff.
