07-29-2018, 02:49 PM | #1 |
Outer Body Mount
I started to do the repair to the passenger floor on my 63 burb and the body supports are rusted out. Since the truck sheet metal is different, working on fabricating something but part of the mount is missing.
Does anyone have any photos or illustrations/diagrams of the suburban body support? Thanks.
1963 Chevrolet Suburban |
08-04-2018, 02:28 PM | #2 |
Re: Outer Body Mount
Your body work, metal skills are looking great. I have a 62 panel, I could be wrong, but I think most of the floor supports look the same. Is that piece behind the door, transition up to the wooden floor? I can get you photos of them etc....Ed.
08-04-2018, 03:31 PM | #3 | |
Planning to fix the body mount before doing the inner rocker floor. More room for access and then can treat the rust up inside the body mount. The piece that transitions up to the wooden floor is further back, Right where the rocker panel meets the rear bedside There is a 90 degree bend that then drops down in between the outerbody mount. I attached a photo of a view from the bottom back of the rocker and then where the floor meets the wooden area. There is a curve there and then the way the floor is flat skews the body mount where it is wider where it meets the outer body. Not sure if there should be a gap or drain hole where as well. The view from the rocker helps to show what is missing on my body mount. The floor photo shows how the 90 degree bend meets the floor. Really love to see a photo if you can take one or three. Front view back view and bottom view. Bottom view being most important.
1963 Chevrolet Suburban Last edited by 63suburban; 08-04-2018 at 03:38 PM. |
08-04-2018, 05:22 PM | #4 |
This is the drivers side, undercoating and drop down for fuel switch ? or something blocks decent photo. Brace looks close, Suburban metal floor goes back further, I will get a better photos of the passenger side later....
08-04-2018, 05:54 PM | #5 | |
To the left of the photo, the drop down is the inner frame to body mount. Pretty sure I should have worded this thread "outer body support". Since it supports the body and does not attach to the frame. Has the rubber bushing w bolt. Photo angles from bottom up would be helpful.
08-04-2018, 06:41 PM | #6 |
Will do, trying to figure out how to get a decent photo that shows details not just a blob....
08-05-2018, 03:17 PM | #7 |
Thanks alot!! really appreciate you taking the time.
The panel looks like the burb supports.
08-05-2018, 03:53 PM | #8 |
Hope it helps, ...there are 2 stamped finger depresions about 4" apart, probably strengthens the piece.
08-05-2018, 04:30 PM | #9 | |
I would have never have guessed there is a lip at the bottom rear of the passenger side body support. Was just going to make the passenger side like the driver's side. Looks like the depressions are the differences on the panel. Same with where the body support bolts to the body. What year panel do you have? if it is not too much trouble, a pic of the passenger side view from bottom or 3/4 angle. Trying to see where the body supports meets the rocker. Thanks!
08-05-2018, 05:25 PM | #10 |
I will try and get a better photo, the shot with the white cardboard shows the bottom edge. That edge is open on rt side and left side, tips away from the 90 degree like it might have been to shed water... I know the undercoating obscures any decent photo. Also looks like about 1/2" up from rocker lip, maybe even, with rocker. I will check.
08-06-2018, 10:04 PM | #11 | |
08-09-2018, 12:31 PM | #12 |
Awesome. Thanks alot. Really appreciate you taking the time to post up those photos.
