11-15-2003, 02:08 AM | #1 |
Blower Motor availability
Does anyone know if you can still get the blower motor for the Air Conditioned (four-season) trucks or is just the blower motor for the trucks with a heater available? According to the service manual, there are 2 different types.......the AC blower motor has a 50% higher blower speed than the regular one for just a tuck with the heater. If so, where can you get the higher speed one? Anyone know? Thanks for any info!
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
11-15-2003, 02:14 AM | #2 |
Formerly yellow72custom
You should be able to get one at the auto parts store....i picked one up for about $20 last year for my non-AC pickup.
If i remember correctly, blower motors are the same for most GM products until like the mid-ninties.....not totally sure on that, but i think i remember hearing it on the board.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-15-2003, 02:20 AM | #3 |
Well, the reason for my question is because the service manual specifically states 2 different type motors available and I'd swear I've read of others complaining about their blower motors not being as powerful as their past motors.
11-15-2003, 02:42 AM | #4 |
its all about the +6 inches
There was a blower motor style chainge between 72 and late 70's.
11-15-2003, 04:16 AM | #5 |
1971 Service manual lists following info:---
Blower motor ---- Heater only-- 6.25 amps; 2550 to 2950 RPM Heater w/air cond. -- 16.5 amps; 3700 RPM (min) There is a considerable difference in air output..... so by all means go with the blower motor designed for aircondioning...........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
11-15-2003, 04:52 AM | #6 |
We stock both, we don't have a selection when you add it to cart to specify A/C or Non-A/C on the blower motor because when you reach check-out we require you to fill in a form stating if truck is A/C or Non-A/C, etc.... and without this info filled in the shopping cart will not accept your order.
GMCPaul |
11-15-2003, 05:44 AM | #7 |
Merciless Butcher
I think the blower motors for A/C equipped truck had a rubber drain hose that attached to the bottom of the motor. Has anyone else seen this? The non-A/C blower motors don't have the provision for this drain hose.
Your Bought And Sold....I Got Your Soul! |
11-15-2003, 05:47 AM | #8 |
What brand name(s) do they go by Paul? I have one by Electrohome (12 Volts DC , 1/8 HP, I think) that I think is out of a Bluebird bus. I was considering using it for powering a small cutting wheel but realize I would need a transformer/rectifier setup. Decided that a small AC (thats alternating current not air conditioning) motor would work better for that anyway.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
11-15-2003, 06:38 AM | #9 |
gone bad...... the hose you refer to is a hose supplying air from the heater/air plenum back to the motor ... hose is used for cooling purposes as the blower motor does draw considerable amps and will get quite warm !!
11-15-2003, 07:11 AM | #10 |
Merciless Butcher
Thanks Jim...I learned something new today...Have a good evening??morning
11-15-2003, 12:05 PM | #11 |
Its Magically Delicious
bought mine at schucks for 15 bucks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
11-15-2003, 01:26 PM | #12 |
I am a Referee of life.
My ?? iso they fit interchangably?
It would sure help get some heat to the rear of my panel.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-15-2003, 01:46 PM | #13 |
Firefighter
Yes they will interchange, however I have heard that using an A/C motor on a Non-A/C truck will couse problems with the switch and relay. I don't know if it's true or not maybe sombody else has heard something about this.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
11-15-2003, 02:11 PM | #14 |
Project Junkie! Fishing Poor!!
Why use the non air motors when the air motors are available. Both are reproductions, and are good ones. I have istalled both motors in our shop and am extreemly happy with the fit. I do have them in stock also. You can also buy one from GM, however they have an updated version that requires you to purchase a spacer also, because the squirrel cage is longer. Here is a link to where you will find them in our website: http://www.classicheartbeat.com/heater_&_a_c.htm
WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
