Old 07-31-2018, 09:13 PM   #1
richard2717
Equal opportunity joke ofender
richard2717's Avatar
lowering blocks
I am upgrading my 68 panel to disc brakes. The new spindles have a 2" drop. I have been looking at the 2" lowering block for the rear trailing arms instead of lowering springs. Anyone have experience with the blocks or should I steer clear of them and use springs? I dont want it real low but I don't want a bad rake either
TIA
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 07-31-2018, 11:14 PM   #2
HO455
HO455's Avatar
Re: lowering blocks
I have had 2" blocks on my Blazer for over 100,000 miles with no issues. Blocks get you lower without loss of suspension travel which makes for a better ride. The only down side I know of is reduced ground clearance under the trailing arm or spring. Which for almost every pavement driven vehicle it is not an issue with 2 inch blocks. That being said 2" blocks and 35 series tires on 15" wheels might not be a good idea. But some measuring before hand should reveal any ground clearance problems.
Usually you have to replace the u-bolts that bolt the axle to the suspension. Just be sure to go with quality fasteners and you won't have problems. It is a good idea to check the nuts with a torque wrench periodically. Although I have never found a loose one it makes me feel better.
Hope this helps Richard. Thanks again for the window seal!!
RIP Bob Parks.
Old 08-01-2018, 12:49 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: lowering blocks
I used 2" square tubing and made my own blocks on my White '67. It worked good.
LockDoc
Leon
Old 08-01-2018, 07:03 AM   #4
richard2717
Re: lowering blocks
thanks guys. These are the ones I was looking at. They are billet and come with the u bolts for less than $90
Members I have met.
Old 08-03-2018, 12:25 AM   #5
Average Joe
Average Joe's Avatar
Re: lowering blocks
I agree with all the above. I might add that you can probably make your own for less than $50 bucks and an hour of your time. A good spring shop should be able to bend up some quality U-bolts for $40 or less. A 2' long chunk of 2" tubing will be more than enough for a couple of blocks. Cut to length, drill 4 holes, a coat of paint and you are done.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
