Old 08-05-2018, 06:47 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Installing a RetroSound Radio into dash cutout.
So my dash has been cut from a previous owner I guess to accommodate a more modern radio. But I wanna install a RetroSound Radio. But can it be done using the existing cutout using a mounting kit like 38-8586 from LMC?? Or is it just best buying a new dash?? I know there's a dash repair kit, but I don't now if a clean repair weld can be "that" clean. Thanks.
desert-rat is offline   Reply With Quote
Old 08-05-2018, 08:32 PM   #2
Smitty
Smitty's Avatar
Re: Installing a RetroSound Radio into dash cutout.
If you found a competent body man. You'll be ahead having the existing dash repaired. Will be far cheaper than replacing the dash. But no doubt still kind of pricey. My cab had serious rust issues that were only rectified because my mother passed. She left me a little coin and the wife said that if I wanted to do the truck, now was the time. Had been collecting parts for 20 years HOPING I might one day be able to do the truck right. All the while it was deteriorating in the driveway. Used for menial tasks. The down side is that now that it is done. It no longer qualifies for menial tasks.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 08-05-2018, 08:43 PM   #3
72c20customcamper
72c20customcamper's Avatar
Agreed any competent body shop an do it seemlessly, it's no different than patching a fender or door. I am going to replace my dash because the po cut the radio out and installed speakers where the a/c outlets would have been if it had a/c. So it would be three patches. Going to do this myself as my uncle owned a body and I worked with him from time to time.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-05-2018, 08:37 PM   #4
darrellyates
The dash repair kit can be used very successfully. I used it to repair my cut dash.
darrellyates is offline   Reply With Quote
Old 08-06-2018, 03:10 AM   #5
desert-rat
Wow! That is a clean job. Looks great.
Old 08-06-2018, 03:15 AM   #6
desert-rat
Thanks all for the replies. Looks like the patch panel is what I'm gonna do. Way cheaper than a new dash. I currently have a body shop replacing the driver floor and both rocker panels and inner rockers, drip rails, and patching the holes on the cab corner. I'll check out his work to see if he can do a clean job on a radio patch panel. He does mostly custom jobs. He does custom work on harleys, classic vans, and classic trucks. So I'm guessing he just might be the right shop.
Old 08-06-2018, 10:18 AM   #7
davepl
davepl's Avatar
If you're going to invest in welding a patch in for the radio, might I humbly suggest a better radio? The [Custom Audio stuff that I THOUGHT you meant] is hugely bad, and I mean bad. And I had low expectations.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-06-2018, 03:24 PM   #8
davepl
davepl's Avatar
You're right, I did mean Custom Audio Sound. Thanks for correcting me - I edited my post so as to not steer anyone wrong, if you could edit where you quote me, I'd appreciate that!
I don't have ANY experience with Restrosound.
Old 08-06-2018, 03:42 PM   #9
Grumpy old man
Grumpy old man's Avatar
Don't waste your time and money using a vendor provided dash repair panel . Just put a want to buy ad in the classified section and buy the lower half of the dash and weld it in across the dash under the dash pad . you'll save a ton of labor cost.
Old 08-06-2018, 04:01 PM   #10
Grumpy old man
Here's what you want right here ,Hurry before it's gone .
http://67-72chevytrucks.com/vboard/s...d.php?t=768939
Old 08-07-2018, 09:28 AM   #11
darrellyates
OK. Just for giggles... I see you said "RetroSound" radio, and later "Custom Audio"... So not sure what radio you are wanting to use.
I did purchase, from a vendor on this site, the RetroSound radio. I won't say that I love it, but I do like it. I like it because it stays true to the look of the period. And, it has most all modern features. I wanted the look to stay close to stock, so that's why I went with it. Since then, I've found that an original radio can be converted to RCA outputs and add bluetooth to them, so I should have gone that way. However, the RetroSound works as advertised, and provides a decent signal to the amplifier. It also is less expensive than having an original upgraded, unless you can do that yourself (I can't).
There is an audio section on this site with a lot of good information.
Good Luck!!
Old 08-07-2018, 09:47 AM   #12
beaterku
beaterku's Avatar
My dash was cut when I bought the truck. I used the faceplate that came with my Retrosound. I used the buckets that come with the radio to sandwich the radio to the dash and used the bracket in the rear of the radio to hold it steady. It's held steady for 5 years now.
beaterku is offline   Reply With Quote
