Old 08-09-2018, 03:06 AM   #1
Dodge68charger
Any Tips Or Tricks On Bending Brake Lines
Just Wondering If Anyone Has Any Tips Or Tricks.. I Heard There Is A Formula.. Seen Some Of The Frames On Here And The Bends Line Up Perfect With The Contours Of The Frame.. Clean And Tight
Dodge68charger is offline   Reply With Quote
Old 08-09-2018, 05:31 AM   #2
Artofdeath
Artofdeath's Avatar
Re: Any Tips Or Tricks On Bending Brake Lines
They make benders. Here is a NAPA know how article on bending lines.
http://knowhow.napaonline.com/tips-f...nd-fuel-lines/
Artofdeath is offline   Reply With Quote
Old 08-09-2018, 06:14 AM   #3
Killer Bee
Killer Bee's Avatar
no offense but didn't see much useful info in that napa article..
try searching 'how to bend hydraulic tubing', here's a couple I found quickly;
Tube and pipe basics: How to achieve the perfect bend
Bending 101
having been bending heavy wall, high pressure hydraulic tubing for over 25 years, I can suggest a couple of things..
invest in good tools or don't bother as the results may no not impress you..
practice, practice, practice.. try your hand with scraps or small runs first to see if you have the skill..
some folks can pick it up and make nice solid tubing runs, others can't..
if you've got the knack, continue challenging yourself and upgrading the tools to meet your skill level..
I have some pictures of some of my work around here somewhere, always enjoyed tube bending projects
bent .120 wall .625 SS for Navy Seal Mark V transport trailers for C17 / C5, 7200 psi hydrostat control plumbing, various motion bases for amusement rides including hpu's for jurassic park at universal, etc.
I'll add more later, good luck!
Last edited by Killer Bee; 08-09-2018 at 06:22 AM. Reason: give me a break, it's late :)
Killer Bee is online now   Reply With Quote
Old 08-09-2018, 06:56 AM   #4
Zeroman
Zeroman's Avatar
I bought a roll of heavy gauge copper wire and used it to map out tight turns and difficult routings.
Then used it as a guide to bend the tubing.
Zeroman is offline   Reply With Quote
Old 08-09-2018, 07:43 AM   #5
Grumpy old man
Grumpy old man's Avatar
^ that's good but heavy coat hanger wire is free . Your wife has too many clothes hanging in the closet anyway
Old 08-09-2018, 09:11 AM   #6
dfwright
dfwright's Avatar
Go with NiCopp and don't fear the bending anymore
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
