Old 08-15-2018, 09:51 AM   #1
old51sedan
old51sedan's Avatar
Question Air & heat
Are there any sponsors/vendors that most of you are buying your Air Conditioning from? Are most of you buying yours locally or sending for it and installing it yourself. I just got a quote for about 1400.00 for a vintage air unit, is that in the ball park?
old51sedan is offline   Reply With Quote
Old 08-15-2018, 10:01 AM   #2
davepl
davepl's Avatar
Re: Air & heat
I think it begins and ends with Vintage Air. I've never owned one of their setups, but it's the way I'd go personally.
I've never heard anything but good about them, and people aren't usually very kind. Now imagine a product like an AC retrofit that's hard to do and it's a wonder people don't trash them constantly, but everyone seems to love 'em!
I'd do my own, but not much scares me. If you're not into cutting your firewall and gutting your dash and modifying pulley arrangements and adding compressors, then you might want to have a shop do it. I'm actually on the fence. I know a guy who has done a dozen, so it's tempting to lean on him for it.
BUT FIND A SHOP THAT HAS DONE MANY. Don't let some joker learn on your truck.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-15-2018, 04:05 PM   #3
old51sedan
old51sedan's Avatar
Re: Air & heat
Well, like I stated my truck is stripped including the dash with exception of gauges which is no big deal. I figure it would be a good time rip out the heater & etc. and to drill holes for the air vents. I've never installed a system, but I'm up for it. Thanks for the reply.
Old 08-16-2018, 10:38 AM   #4
davepl
davepl's Avatar
Re: Air & heat
That's the perfect time. I don't think the systems are super complicated but it's hard to get access to some areas, but if you've got it stripped down, all the better!
Old 08-15-2018, 10:34 AM   #5
morepwr
Re: Air & heat
Vintage air. I have one in my truck and also have a unit in a Cutlass. It could not work any better and it fit great.
morepwr is offline   Reply With Quote
Old 08-15-2018, 10:51 AM   #6
68 P.O.S.
Re: Air & heat
Has anyone heard of, or used these guys? https://www.restomodair.com/shopprod...te-a-c-system/ I've been looking at their setups for quite awhile, but I have a lot of other more important things to do to the truck first, so haven't pulled the trigger yet.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-16-2018, 04:21 AM   #7
F.A.A.benny
Re: Air & heat
They are classic Auto Air's premium brand. I use to work for CAA so I've talked to the guy who runs it a few times. They have a following on Instagram. Have also seen them at one of the power your stops.
F.A.A.benny is offline   Reply With Quote
Old 08-16-2018, 10:20 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Air & heat
Original Air Group is who I use. The unit's fit and they will make a old GM unit like new again if you want to send it to them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
