08-16-2018, 03:57 PM | #1 |
Radiator 70 c 20
Anyone know the exact radiator measurements on a 1970 c20 with 350 small block i tried searching came up empty ,thanks in advance.
Posted via Mobile Device |
08-16-2018, 08:08 PM | #2 |
Who Changed This?
Re: Radiator 70 c 20
I have a 400, so I'm not much help. Somebody else should chime in, sooner or later.
08-16-2018, 10:08 PM | #3 |
08-16-2018, 11:31 PM | #4 |
Who Changed This?
Yes. If you have the truck, do you need to know what needs to be measured, for you to get the right dimensions?
08-17-2018, 08:47 AM | #5 | |
That would give me pretty much ball park dimensions right? Thanks Posted via Mobile Device |
08-17-2018, 10:10 AM | #6 |
Will the size of an aftermarket aluminum / plastic be fine, or do you need the size of the original copper / brass?
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
08-17-2018, 11:17 AM | #7 |
Who Changed This?
My radiator is 34" from outside to outside of the tanks, and 19" high. You could have one that is narrower if you have a 350 without AC. Do you have the radiator core support available to measure? The hole should be about 29" for the radiator like I have since it stops at the edges of the core.
08-17-2018, 11:19 PM | #8 | |
08-17-2018, 11:20 AM | #9 |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-17-2018, 11:26 AM | #10 |
Two radiators I found with a quick search...
Hope this helps. Bill
08-17-2018, 04:56 PM | #11 |
Who Changed This?
That 28-3/8" core size corresponds to the hole, closely enough. I'll have to measure my core's thickness- it is a four-row brass job.
08-17-2018, 11:20 PM | #12 |
08-18-2018, 10:10 AM | #13 | |
08-18-2018, 12:37 PM | #14 | |
