Radiator Photo
My 1985 Silverado Radiator doesn't seem to fit like the stock one did new, and I was wondering If anyone had a photo of a OEM one. My aluminum one is about 3 inches to short and 2" to narrow. And it's suppose to be the dimensions that fits. I am confused.
I'm trying to get a tighter fit so my a/c condenser get's better air flow. My a/c doesn't cool great at slow speeds. |
Re: Radiator Photo
Or if anyone has a factory radiator still in there early 80" Silverado with a/c and auto tranny, maybe you could measure from top to bottom and side to side for me.
Thanks |
#3 | |
![]() Join Date: Dec 2009
Re: Radiator Photo
Hope this helps.
Re: Radiator Photo
From my 75 350 w/AC/Auto: 18.75 H, 33.75 W, 2.5 D. Not factory but replaced when brass-copper was the standard replacement. IIRC - was a drop in replacement.
Width is a bit of a guess as I was trying to eyeball measure around the hose hump on the driver side top. Width tries to exclude the hose hump. I think 81 was when the radiator core support got the major redesign. |
Re: Radiator Photo
It sound like you have the older style rad 73-80 for a big block, (taller and but less wide) the 81-87 tend to be shorter and wider. I do believe that some of the diel rad in the 81-87 are like the 73-80 and a few 454 depending on option set up. my old 3 core copper rad 2.5 W by 3.5 long tanks, and between tanks 20-7/8H x 28-1/2W I forgot the paper I will post them to night.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 08-20-2018 at 07:04 AM. |
Re: Radiator Photo
I have a Champion with Shroud and 2 .. 14" fans.
overall: 19" tall x 28 1/4" wide Inlet: 1.5" located on driver side. Outlet: 1.5" located on passenger side. Tanks: 2 3/4" thick Mounting Type: Saddle Mounted Last edited by 85/Silverado; 08-19-2018 at 09:26 PM. |
Re: Radiator Photo
You can see the problem, I had to cut the top mount to fit around the cap, I have shims on the bottom and it still needs to be higher,
![]() Join Date: Jul 2000
Re: Radiator Photo
Well, there at least 3 different radiator sizes. I went though 2 before I found one to replace my OEM radiator. That's a good reason to buy from a local parts store. And don't let anyone tell you aluminum core with plastic tanks is a bad thing. It's what all the new vehicles use.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Radiator Photo
Well this is the short now since this the third time re set twice .
You need rad support that mount to the motor side of the Rad support for LMC or the 6CYL. mounts 19" high rad's there is two style 305, 350 shrouds one for the lighter cooling use with 6CYL. style mounting brackets . heavy cooling 305, 350, 454 like the top rad support mounting brackets you have 20". There lots of Option LMC has them . Oh you will need rubber for the bottom if you do not have them.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Re: Radiator Photo
I guess I'll have to get someone to build me a custom shroud to fit between the mount and the Radiator so I'll have a tighter fit for increased air flow for the condenser.
I have the rubber (9) mounts but they were not big enough to keep the thing up high enough for the brackets to hole the Radiator tight to the front. I know they make a larger size radiator $355.00 looks the same as mine. |
![]() ![]() Join Date: Jul 2002
Re: Radiator Photo
The radiator is too short for you application. On the stock fan shroud/mount for the smaller radiators there is a cover for the top of the radiator that covers that gap and helps keep the air flowing thru not over that radiator. If you don't want to get the taller/larger size and mounts, then make a cover so the air won't go around the top of the radiator. You can make it out of metal or a heavy rubber matting/stripping.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-20-2018 at 11:48 AM. |
Re: Radiator Photo
Thanks for the picture so now get a idea or two.
