![]() Join Date: Oct 2012
wtb shifting rods from a 67-72 3 speed
I am needing a set of shifting rods from a 67-72 c10 with the 3 speed on the column price shipped to 72560 Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: wtb shifting rods from a 67-72 3 speed
i will ship you a set for $50 total. They are from a 6 cyl truck saginaw transmission.
![]() Join Date: Apr 2003
6 cyl. or V8 ?
The rods that shoveldug has should work for you.
Do you have paypal
Posted via Mobile Device |
Yes I do. It is dwl65101@yahoo.com I also sent you a PM
If nothing works out I have a bunch of the rods. But they are all mixed up and I'd need help sorting out what is what
Ok money sent Thanks
Just a heads up the shifting rods from a 67-69 chevy truck will not fit a 65 with a 68 3 speed transmission
Those were 67-72 6cyl rods for 3spd, correct? And you are saying those will not work on a '65 with V8 and 3spd. So have you tried 60-66 V8 rods for 3spd? Is the engine mounted in the 6cyl position (dist. back into the firewall) or the V8 position?
They will not work on my truck. I have a 350 with a 68 3 speed. The truck is a 65. The rods are too short and will not clear the firewall and the clutch z bar. I was under the truck a while trying everything to make them work. I have not tried the 60-66 v8 rods. I think the engine is in the 6 position but not sure. The original bell housing was in the truck when I got it bolted to the factory cross member right behind the engine.
Are the engine frame stands in the front or rear holes? How much room between the distributor and firewall?
The back holes but like I said the bell housing is bolted to the front cross member. It cannot move forward to my knowledge Any way I went today to buy a tranmission and driveshaft from a guy and ended up buying the whole truck so I will have everything I need to put the right 3 speed in it
