Cab Swap
While I was looking for the elusive S10 Grill Bowtie at the local Pull A Part today I found a 73 swb stepside 2wd. Cab is rotted out on the bottom, rear axle gone & front cap is almost gone. One good door. But bed is nice, no wood though. I have an 85 cab & front cap at home & a 73 Blazer that is rusted down. Here is enough parts to put together a swb stepper 4wd!
![]() Question is will the cab bolt up to the existing cab mounts or would they need swapping from the 85? I still have the whole 85 truck it is wrecked on the front frame horns. Thanks |
Re: Cab Swap
cabs mount points are the same for truck cabs . 73-87 . just use body mount kit for the year of the frame .
if talking about using the blazer frame and making a TRAZZER then its easy . core support and front mounts line up with truck cab on blazer frame . rear cab mount is a simple lift bracket to make out of c-channel . then shorten the bed down and bolt it on with few mods .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: Cab Swap
Yes super simple swap. Cabs are identical in the mounting department. What SweetK30 said on using mounts for frame year and not cab year.
Re: Cab Swap
Hey I notice on the LMC that the doors have a break in year about 1973 -76 & another part # for '77 up.
Whats the difference in the doors early to late? Thanks |
Re: Cab Swap
Pretty sure the difference is the Door panels. You'd need to match the panels to the year door. Other than that I don't think there is a difference. There are smarter people out there so we'll get it straight.
xrcr |
Re: Cab Swap
yep fit the same but punch outs for door panels and trim .
Re: Cab Swap
Got it!
Thanks! |
Re: Cab Swap
The door shell changed to accommodate power window mechanisms, coincided with door panel change. There are no factory power window mechanisms for 73-76, '77 and later.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
