![]() Join Date: Jan 2018
Vintage Air: SBC to LS Question
It is about time for me to add AC to my originally equipped AC truck. I am currently running the original 350 with v-belt but plan to swap to LS once the SBC kicks the bucket (maybe 6 months, maybe a year or more). It is my daily driver and I crank out a lot of miles. With this said, I want to install vintage air now and was wondering if I could just swap the pulleys/brackets when I convert to LS or if it may require a new compressor/pulleys/hoses etc. I couldn't find much to answer this question. Thanks.
#2 | |
![]() Quote:
Refer to my initial statement though on that topic. You will be miles ahead if you just bite the bullet and get the complete package for your application. I purchased mine from Summit and the price was better than from VA direct. Going to have mine charged today as a matter of fact. |
Re: Vintage Air: SBC to LS Question
Yeah, I am getting the full system. My question more is I am putting on a SBC full system on and then converting my motor in a year or so to LS...can I replace the pulleys on the compressor (v-belt to serpentine) and brackets for the LS or will I need to replace the compressor, pulleys, and potentially lines?
![]() Join Date: Sep 2016
Talk to mcb Matt in the vender section , he should be able to answer you question . I believe the kit is the same but you will have to buy a ls bracket later on when you swap.
Posted via Mobile Device |
I’m prettt sure you’re not gonna change the pulley on the AC compressor and the small block bracket will not work on the LS. Compressor location would be similar if you go with the high mount, so your hose length would probably be close enough. So if you buy now, you’re gonna need a different compressor and bracket. If you’re looking at an LS in 6-12 months, I would wait. That way you don’t have to buy two compressors and two brackets.
You could just call Vintage Air directly.
I bought my system from a vendor on this site, but for all of my technical questions I spoke to the Vintage Air Tech Line. |
Old member
You have two choices.
Buy everything now and have to swap everything when you go to the LS motor. The ac will all be the same but depending on where you mount the new LS compressor will mean new brackets and compressor at the least. Wait until you do the LS swap and just buy one time. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
