Lowering my c20
Ok ive searched and either missed it or didn't look long enough (adhd). Im looking to lower my c20 about 4-5 inches in the rear, and about 2 inches in front. I have 16" wheels and stock 31" tires currently. Im eventually going to a 20" rim and about a 30" tire. For now, can I take any leafs out to lower it a couple inches in the rear? And ive read about cutting front coils by 1 coil safely. How much drop could I get cutting 1 coil up front, and taking the overload leaf and however many others safely in the rear? I wont be using the truck to haul more than a light boat and an atv (2000 lbs. Max at a time).
If there is a specific thread or build on here please link me to it. EDIT** Im just wanting to do a budget type drop until I get my new wheels. Then, I will be going normal route and getting new suspension.
'72 C20 Custom Camper, crate 350, T400, Dana 60, ps, a/c |
Re: Lowering my c20
I took two out of the rear dropped about 1 1/2 But you need to shim the u bolt nuts to clamp the rear tight. Mine bottomed out before they were tight. Haven't done the front yet but I'm going to use drop spindles. And then 2 inch lowering shackles in the rear.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: Lowering my c20
It'll look sweet once you do the full rebuild. I'm still working on it, but this is the stance on ours. lots to do yet. 1972 Custom Deluxe 20 Custom Camper.
Re: Lowering my c20
how much did you drop yours pepper??
2008 GMC 2500HD 6.6l Duramax Diesel 67 GMC long bed 2wd my "main squeeze" 85 Toyota project, SBC, TH350, D60 front, D70 Rear, 3 linked Front, 4 link Rear. 43 Willys, family heirloom ![]() |
Re: Lowering my c20
5.5 front. Flipkit and pulled bottom leaf in back, approx. 7.5. It's not done yet as I'm adding helper bags in the rear for loads and trailer duties.
#6 | |
Re: Lowering my c20
...actually now that I look at it, it looks like yours might be just on top of the tires? Its kinda dark around the tires in the pic.
Re: Lowering my c20
Hey Pepper looks like you made the spring under pad yourself, is the any measurements i would need to make one or does it pretty much just to keep the pinion angle off the stock pad?
#8 | |
Re: Lowering my c20
