Power steering fluid loss.
On my my '85 C10 Sliverado with a replacement 350 SBC engine, my power steering fluid is going somewhere. Removed my power steering pump, inspected it, and found no evidence of leaks. I also replaced both hoses. However, I am still losing fluid at a rapid rate. I have even popped the hood open, and watched the all the components, while a friend turned the wheel, and found nothing. The only thing I can think of, is the steering gear box. But I see no evidence of it leaking. Does anyone have an idea, what could be happening? Thanks.
PS: I know it has been a while since i have posted here, but I will try to be a little more regular. I cant believe how much time has passed. |
![]() ![]() Join Date: May 2015
Re: Power steering fluid loss.
My blazer was losing fluid bad...it was the output side of the gearbox seal...
Run down to AZ & pick up a cheap UV test kit. Glasses, Light & Dye.
You'll be able to find it then. That stuff works so good you can find the money missing from your wife's checking account! ![]() Last edited by andyh1956; 09-10-2018 at 11:15 AM. |
Thanks, I will investigate this further. I will post, if I fix it.
