09-17-2018, 02:18 PM | #1 |
S-10/ Blazer rear rotors
Does anyone have the dimensions on the rear rotors for the late '90's Blazers? I have a set of rotors that were part of a Baer Brakes kit for a full-size truck that they put together. Yeah, I know, two different vehicles, but supposedly this kit was put together with those particular rotors and I want to verify that fact. I used a different kit on my K1500 and I've had this one on the shelf. It's time to sell the parts and I need to identify them. (These were five lug rotors also...)
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
09-17-2018, 09:35 PM | #2 |
Re: S-10/ Blazer rear rotors
I took pics of these rotors I have. They are 11 5/8" or 295mm in dia. Thickness is 20mm and the height of the hat is 60mm. Depth of the hat is 54mm. The lug holes were drilled by Baer.
09-17-2018, 09:38 PM | #3 |
These may also fit '94-'96 Chevrolet Impalas (?).
09-19-2018, 08:46 AM | #4 |
Disc brakes came out in 98 for the blazer. 97 and earlier were drum.
98-05 2wd rear rotor: 296mm diameter, 20,mm thick, 72.8mm total height(so the hat would be 62.8mm tall) 98-05 4wd rear rotor: 295 mm diameter, 20mm thick, 95.3 mm total height(so the hat would be 75.3 mm tall) From the measurements you gave, they are close, but not a direct fit for a blazer. 94-96 Impala SS rear rotor: 295mm diameter, 20mm thick, 59.1 total height(so the hat would be 39.1mm) That's not a direct fit either |
09-19-2018, 12:47 PM | #5 | |
Thanks for that info. I think I "ballparked" that height measurement and I need to take that measurement again on a flat surface with my digital caliper.
09-20-2018, 04:18 AM | #6 |
I think these are Impala rear disk rotors. Total height is approx. 60mm and thickness of the rotor is 20mm (39.1mm + 20mm). That math is close enough for me.
