Recommendations on parts supply.
Hi all,
I am getting together a parts list for my Longhorn, I would like to ask for recommendations on where to buy. I want to buy HIGH QUALITY parts, avoiding china junk if I can. I need: A/C stuff, hoses, filter, O-ring’s etc. it has factory air. Maybe a heater core, I need to pressure test before I buy one. Exterior door handles (mine are pitted) Centre lap seat belt, buy I would like the buckle the same as the existing ones, (has factory lap retracts in black) Seat upholstery, currently has black vinyl with hounds tooth insert, seat are embossed in centre section. Like to replace with the same. HIGH QUALITY carb rebuild kit, it has 4 brl Rochester, all the ones out here are china garbage, wrong base gaskets, just a total waste of money. Lower body mouldings, the wide alloy ones, I have a few with some damage, so factory style so they match would be great. I have looked a few vendors who have been mentioned here, Pauls, LMC, heartbeat. I would just like to know who sells decent stuff, shipping is too $$$$ to allow buying parts several times to get a nice one. The Air Con is my priority, I have a few months before it 100 deg f ++ and plan on being cool. Any help would be good. PS: Is it worth trying to get the cruise control working? Are they reliable? Mine has most of the stuff there, but harness is cut and the switch in cab is missing (steering column mounted) I also want to add power steer, but need everything, pump, mounts, hoses, box, pitman arm. Does anyone do a kit to suit a Small block with factory A/C? Thanks |
Re: Recommendations on parts supply.
I just placed my first order after comparing a few places and went with Classic Industries. I was looking mainly for rusted out floor parts and they had 25% off for another week or so. I should get my order Wed & can tell you if I made a good choice or not, but the salesman told me it was 16-17 gauge steel.
Here's my thread & folks input: http://67-72chevytrucks.com/vboard/s...d.php?t=771563 If you find a good car rebuild kit, let me know from where. That project is coming up soon. Good luck |
#3 | |
The outer cab floor panels were both 16 gauge steel. The smaller parts (front floor cab supports (2) and Front truck door hinge pillar (LH)) looks to be 18.5 gauge steel. The sending unit float & filter screen look alright, won't know if they work until I install them. |
Quality parts are getting harder to get.....I Special orderd brake hoses from Napa only to find Chinese parts....Just ordered and got AC DELCO brake drums from Rockauto, $35.50 each...Chinese made but look to be like OEM and very nice....Good luck.
BlahBlahBlah
Shoot Wes at Classic Heartbeat here on the board a PM. He only sells quality parts, and he has a stellar reputation. My guess is that he has probably sent parts to your part of the globe. Seriously, give him a shout.
![]() Join Date: Jul 2001
First off, Welcome to the best GM truck web site on the net, bar none.
![]() And we always welcome pictures of trucks and on going builds. Another thing to consider besides the mentioned parts suppliers is to become a dues paying member. Best $25 a year US currency you will EVER spend on your truck. There are a LOT of good quality parts selling members here, several have some high quality NOS items. Being in the Land Down Under shipping will NOT be your friend unless you have a US address you can use then relay somehow to Australia. Also, a nod for Wes at Classic Heartbeat, the man KNOWS his trucks. Have used him and GMC Paul both with great results.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Hi all,
Thanks for the replies, just what I wanted to hear. I did some more checks this afternoon, the compressor is working fine, clutch is good, pulls a good vacuum and holds it. The heater valve functions and has no leaks, the external air door actuator fonctions and holds a vacuum. So I think that I will order the hose and muffler arrangement, driers, orings, small hose from drier to tx and pao replacement/upgrade. I need to start another thread on the a/c. So many questions |
If you want high quality, that takes LMC out of the equation. I have personal experience with Classic Heartbeat and Frank's Pick-M-Ups on several occasions since they're local to me. Both Wes and Frank are great guys to do business with and have high quality products. Both are members here as well. I've heard great things about GMC Paul's as well.
72 C10 lwb fleetside -stock 350/350 combo |
#9 | |
![]() Join Date: Oct 2011
(I call them 15 minute parts...just enough time to take a few pics before selling the truck that they got mounted on, lol) Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Here are the places I've used:
https://www.classicparts.com/ - Lots of good stuff. They deal specifically with these trucks, so you will find a lot of good stuff but it can get expensive. https://www.rockauto.com/ - Mix of everything from junk to decent. I usually go here for engine, suspension, drive train, HVAC. AC Delco Professional series should be good, and Moog for anything suspension. Stay away from AC Delco Advantage - they are rebranded junk. https://quadrajetparts.com/ - Everything you need for a quadrajet. I ordered a handful of parts from here. Seem decent. Good prices on things like gaskets, I buy them 5 at a time so I have spares. https://www.summitracing.com/ - Lots of good parts, but not much specifically for our trucks. I've ordered a lot of small block parts and generic parts from here.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
![]() Join Date: Aug 2004
Look into the POA update VS adjusting the valve before you spend the $$. I personally don't think its a good idea to do the "update". The POA system will get you colder, especially if you can locate R12.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
