1976 C10 LQ4/T56 build
So I've been gathering some parts to get this project underway and it's time to start documenting it. I've currently have a 327/saginaw 4 speed in my truck and swapping it out for a 6.0 LQ4 and a T56. I will also be installing factory low back buckets with console and hopefully some Vintage Air with the LS compressor.
This list is not everything, I know. This is more to keep me somewhat organized, and when I am done hopefully will be helpful to others as I will update part numbers as I go. What I have: LQ4 complete pull out F-body T56 with Texas Drivetrain Performance's stage 2 build and mid shift conversion factory hydraulic clutch pedals (bushings?) GMPP Flywheel 12571611 GMPP LS7 Clutch 24255748 Tejas Steelworks engine mounts Tejas Steelworks trans crossmember c30 hydroboost unit ARP flywheel bolts 330-2802 ARP pressure plate bolts 134-2201 ARP bellhousing bolts 134-0901 ARP engine mount bolts 134-3102 (needed 8 bolts but kit only comes with 6, so ordered 2 kits. have 4 spare if anyone needs 2) What I need: t56cablespeedometer.com mechanical speedo drive conversion CAGS delete plug ICT 551478 ordered VSS sensor ACDELCO 2134666 RA reverse lockout solenoid ACDELCO 19180052 RA reverse light switch ACDELCO 14069600 RA Throwout bearing 24264182 EZ bleeder^ clutch alignment tool DORMAN 14523 RA pilot bearing 14061685 cam engine mounts Anchor 2292 RA trans mount Anchor 2392 or 2811 RA Lone Star Dyno engine harness clutch master cylinder find location for oil pressure line engine lift plate 94-99 Chevy 6.5L diesel pedal for DBW 87-91 31 gallon Suburban/Blazer gas tank setup http://www.captkaoscustoms.com/blazertank.html (possibly Boyd's instead) sending unit^ fuel pump^ 454 radiator setup Feel free to comment and ask questions, but right now I am in the planning/buying parts stage and will start once I get more of the parts here. ![]()
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() Last edited by dooce; 10-01-2018 at 09:46 PM. |
![]() Join Date: Jun 2016
Re: 1976 C10 LQ4/T56 build
You will love the 6-speed :-)
Check out my build thread, I just finished the truck. I'm sure it will help you with the "unanswered" questions you will soon encounter. Or just holler at me on here. Bubba |
#3 | |
I just finished looking through your build thread, looks good. http://67-72chevytrucks.com/vboard/s...d.php?t=747247
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
