11-17-2003, 08:54 PM | #1 |
Pick'n up the pieces!
Mounting flanged aluminum gas tanks
I finally scraped up enough green to buy an aluminum gas tank. It has a flange that run the full length of the tank on each side that can be drilled and mounted to the rear frame section. I think they intended for it to mount solidly to the frame, but I think it should be on rubber mounts. I'm trying to come up with a good plan for this. I know minibike and several others have this type of set-up. Any pics would be apprecaited.
I'm thinking the if the frame has any twisting going on, that it will rip the aluminum tank. Any thoughts welcomed. Thanks, Danny |
11-17-2003, 10:51 PM | #2 |
On the ones I have (built) installed, I use a 1/8" rubber strap between the flange and frame. Be sure to ground the tank to the frame though with a ground strap, for safety (static elect.). If your frame is twisting enough to damage your tank flanges, (witch I don't believe would happen) you need to address your frame ("loose" crossmembers rivets??). If it's moving that much, that would be affecting your wheel alignment (front & rear)
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
11-17-2003, 11:01 PM | #3 |
the frames in these old trucks dont twist very much at all unless they are trash. i definately wouldnt see it twisting enough to rip the aluminum.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-17-2003, 11:12 PM | #4 |
Thanks for the responses. My frame is in very good shape with tight rivets. I just thought the frame might tweek a little when going over uneven pavement. Its got to flex a little or it will fatigue. I guess it would move very little though. 1/4 inch rubber would probably more than do the trick. Thanks again, Danny
11-18-2003, 12:57 AM | #5 |
Mine is mounted directly to the frame with two bolts on each side...maybe three. I'm personally not concerned with the frame moving enough to bother the aluminum tank. I would think the aluminum could take slight movements (something from school about modulus of elasticity comest to mind, but that's getting a little to technical). The only problem I have had, is getting a couple of the bed bolts in after the tank was installed.
69 SWB LT1/4L60E www.classicplace.com |
