09-26-2018, 08:56 PM | #1 |
Aftermarket brake booster question
After getting Clyde all prettied up, I opened the hood to replace the battery and even after all the clean up and touch up, there isn’t much nice to say about under the hood.
The master and booster were sourced about 25 years ago, so I am thinking about replacing with an after market kit, would like y’all a input on what’s available. CPP POL MPB Also any suggestions you may have to put a little bling under the hood would be appreciated. This is the only pic I have that actually shows most under the hood, pretty dirty and it isn’t dirty now. The inner fenders and core support were all powdercoated black also.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-27-2018, 12:25 AM | #2 |
60-66 Nut
Re: Aftermarket brake booster question
They all sell pretty much the same universal aftermarket booster with a universal mounting bracket that does not attach the booster correctly to the firewall and pedal bracket.
09-27-2018, 07:03 AM | #3 | |
I was thinking about a dual diaphragm 8”, thoughts??
09-27-2018, 09:27 AM | #4 |
Moderator
The guy who I bought my box of parts truck from swore up and down the 8" brake booster he bought would fit the firewall. It was the normal GM bracket you see on boosters now days. He was sold on it by the phone sales guy at CPP quite a few years ago. It didn't of course. I did go with Captainfab's bracket and a 10" gm booster booster, works like a champ.
09-27-2018, 11:14 AM | #5 |
Chief, where did you source your 10” booster from??
09-27-2018, 11:32 AM | #6 |
Moderator
Ebay. I bought a general GM 10 inch booster as I recall. Not a very good recall I see... sorry.
Looks kinda like this: http://67-72chevytrucks.com/vboard/s...&postcount=180
09-27-2018, 12:01 PM | #7 |
Ok cool. I’m heading to Good Guys this weekend and will look at the offerings there.
I’ll holler at Captn on the mount tho
09-27-2018, 12:15 PM | #8 | |
Moderator
Everything fell into place with Captainfabs bracket.
09-27-2018, 01:13 PM | #9 |
I purchased the chrome one from auto city classics and then the bracket from captianfab
09-27-2018, 01:57 PM | #10 |
Thanks Y’all, I’ll order one from Captn after this weekends hunt!
09-27-2018, 03:51 PM | #11 |
Never Ending Projects
Master Power Brakes has a new setup that is like the factory type. It has a "bell crank" pivot that allows you to put the push rod in the stock manual brake hole (versus having to drill one an 1" lower). Very slick setup and should be great quality based on other units I have used from them in the past.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
