Old 09-27-2018, 07:51 AM   #1
bbrriiaann1973
Tubular control arms for stock suspension height
I have a 1970 chevy 2wd and I need rebuild the front. I would like to have install a tubular control arm setup, but they say design for lowered trucks. I want to leave the truck with its stock height both in the front and the rear.
Are there any tubular options for stock trucks
Any help would be great
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 09-28-2018, 02:20 PM   #2
External
External's Avatar
Re: Tubular control arms for stock suspension height
Same here. Subscribe me in
External is offline   Reply With Quote
Old 09-28-2018, 02:44 PM   #3
crabman
crabman's Avatar
I bought Tubular A arms from POL (Performance Online) which I have yet to install but I want to keep mine stock not slammed. They told me they would work just fine lowered or not.
1969 CST/10 396
crabman is offline   Reply With Quote
Old 09-28-2018, 02:51 PM   #4
CG
BlahBlahBlah
Im curious why, especially if you are keeping stock, why would want tubular arms vs the stock ones? Not judging, just curious if Im missing something somewhere along the line.
Old 09-28-2018, 03:09 PM   #5
crabman
crabman's Avatar
For me it's about improving the ride and handling but I don't want to slam it, I still like the stock look. The suspension needs to be rebuilt so why not improve it as you rebuild it?
1969 CST/10 396
Old 09-28-2018, 03:24 PM   #6
demian5
demian5's Avatar
Well in the front you should have solid bushings in the control arms. Just redo the ball joints and add a sway bar. If you have a sway bar, upgrade to the poly bushings for it. AND get it aligned with as much negative caster as they can dial into it.
The tube arms are to compensate for the geometry changes in a lowered vehicle.
For the rear, upgrade the trailing arm bushings, relocate the shocks to the rear of the diff and add an adjustable pan hard bar and sway bar.
if you are keeping it stock height, you don't need to spend all that $$
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-29-2018, 08:08 AM   #7
crabman
crabman's Avatar
Good advice.
1969 CST/10 396
