09-28-2018, 01:29 PM | #1 |
Steering column length?
Wanting to put a tilt steering column in my 66. What length column are you guys using? Heard that a 32" should be about right. Or is it more personal preference.
09-28-2018, 03:08 PM | #2 |
Re: Steering column length?
Ididit standard is 35" and new rack & pinion version at 30"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-28-2018, 05:27 PM | #3 |
It's Better With Nitro
The Ididit 1960-66 GM Truck Retro Series tilt column I run in my truck is 32" long from shaft end to end.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
09-28-2018, 07:49 PM | #4 |
Moderator
End of the housings end to end? or end of the shafts end to end?
09-28-2018, 08:20 PM | #5 |
shaft - splined end to splined end.
09-29-2018, 07:56 AM | #6 |
Moderator
Thank you.
I havnt ordered mine yet and the reason I asked is (as you know) ordering one they use these measurements (from Ididit):
