![]() Join Date: Jul 2000
Fuse panel & wiring harness kits
Due to a water leak over much of its life, my 82 C10's fuse panel has lots of corroded, and even rusty fuse sockets -- not from getting wet, but from just sitting above the moisture on the floor. Seems like every few months I have to pull a fuse and use a burnishing tool to clean up the fuse panel contacts. But that's usually a temporary fix. Also, with a battery voltage of 12.6 volts, the dash lamps, headlamps, wipers, etc. see only around 11 volts, so I've got a voltage drop somewhere. And that's with two 10 gauge wires feeding the fuse panel.
Bottom line is I need to replace the fuse panel, and might as well get rid of the bulkhead connectors as a potential problem source, which means getting an entire kit including harnesses. I've installed an American Autowire Classic Update harness on a 66 truck, and really liked it, but for a square body, they cost $845. ![]() Pretty much ruled out Painless because they actually use smaller gauge wire than my factory wiring for panel feed and ignition! (Panel feed is two 10 gauge wires, but they crimp them to two 12 gauge wires 6" before the panel. Huh?) What have you guys used, and are you happy with it?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-29-2018 at 08:54 PM. |
Re: Fuse panel & wiring harness kits
You sure the smaller sections aren't fusible links?
Yes, the kit uses a maxi-fuse instead. And the transition is the last 6" or so before connecting the fuse panel B+ bus.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
