10-01-2018, 05:34 PM | #1 |
Almost Satisfied
Astro Hydroboost - What master cylinder?
I have a 95 Astro van hydroboost and the Astro master cylinder. I would like to run a more modern looking master than the 71 cast iron one. I'm not sure what modern cylinders will work with both my boost and the disc/drum set up. I also assume I will have to use my original proportioning valve?? I don't want to spend the Willwood prices.
I did a search on the forum, but after an hour I found no definitive answer. Any help is appreciated.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
10-02-2018, 12:12 AM | #2 |
Re: Astro Hydroboost - What master cylinder?
I use the astro master as well as the prop valve. works good.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
10-02-2018, 05:53 AM | #3 |
I used my original MC and valve. I only changed the vacuum booster with the hydraulic one (HB)
10-02-2018, 07:33 AM | #4 |
There are a million ways for a master cylinder to not be a good choice: bore diameter, quick take up vs non quick take up (affects the portion that goes into the booster), ISO flares vs US flare type, inboard ports vs outboard ports, front port goes to the rear system vs front port goes to the front system, to name a few.
Having said that I think the Astro hydroboost is a good choice. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-02-2018, 09:09 AM | #5 | |
Almost Satisfied
10-04-2018, 05:41 PM | #6 |
I've run it both ways and it works. they are disc/drum in the astro so if thats what you are running it will be good.
10-04-2018, 06:48 PM | #7 |
Where’s the best place to get a complete Astro setup other than a pick and pull? If I search ebay all I find is just the hydroboost without the master cylinder.
10-04-2018, 07:45 PM | #8 | |
j
White K20 |
10-05-2018, 08:54 AM | #9 |
Auto parts store, craigslist, junkyard.....
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-06-2018, 10:26 PM | #10 |
I'm interested in this swap. Does anybody have any pictures? Am I able to use my stock MC?
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
10-07-2018, 12:13 AM | #11 |
All about them K’s
Look at the last page in the link on my signature...
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
10-07-2018, 03:15 PM | #12 |
Will do....thanks!
10-08-2018, 01:05 PM | #13 |
I've done 2 hydroboost setups.
1970 Nova - used the astro booster and MC for the Astro 1972 c10 - used a booster from an early 2000's silverado and the factory c10 booster For both setups I used an aftermarket prop valve.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
