10-02-2018, 01:11 PM | #1 |
Junior Member
Engine starting issues
Hey guys/gals. Just looking for some ideas... I've got a '71 Suburban with a new gas tank and we're trying to start it for the first time since installing the tank. Before the install, it was sitting for the better part of a year and wouldn't start. I diagnosed a leaky fuel tank and bad gas. I replaced the tank and all the rubber hoses. Today a friend came over to help me get it started. We verified that the distributor is on properly (I pulled it off to prime the oil pump), replaced all the plugs and wires, checked the plug order three times, verified that the dist and the crank were at #1 TDC, and primed the fuel line. We checked the spark with an in-line tester and verified spark. We disconnected the fuel hose at the carburetor and verified that we were getting gas from the pump. Then we cranked the engine a number of times, with a couple of different dist orientations, and only got backfiring (we had poured gas into the carb). We checked for gas from the fuel line to the carb again and this time saw nothing. So we're thinking it's the fuel pump. Any other ideas of what we should check?
FYI I've got a 350 crate engine and HEI. Yes, there's gas in the tank :-D Thanks! |
10-02-2018, 04:03 PM | #2 |
Re: Engine starting issues
Clogged or kinked lines are possible and it would stink to replace the pump and still have an issue.
Verify you’re getting fuel to the fuel pump. I’ve had some vehicles that were very stubborn getting fuel to the pump after running out or replacing a component in the fuel system before the pump. Last edited by Overdriven; 10-02-2018 at 04:09 PM. |
10-02-2018, 05:40 PM | #3 |
Sounds like the distributor is one the wrong stroke.
Very easy to do. How did you confirm that you were on the compression stoke on No 1? |
10-02-2018, 07:26 PM | #4 |
The Older Generation
Even if the pump is not working it should still fire and run for a bit by pouring a small amount of gas in the carb. Is the choke open or closed when you try it. Like Chris mentioned above, it is easy to get it timed on #6 instead of #1 and that would make it backfire..... LockDoc
10-02-2018, 09:22 PM | #5 | |
Junior Member
10-02-2018, 10:00 PM | #6 | |
LockDoc
10-02-2018, 09:21 PM | #7 |
Junior Member
10-02-2018, 09:54 PM | #8 |
Backfiring confirms you have 2 things, Fuel and spark, just not at the right time. you will get some compression on the exhaust stroke too, as the exhaust valve is only just beginning to open when the piston is heading up on the exhaust stroke. If you take of the rocker cover, you can confirm you have a closing intake valve as the timing mark for no 1 is coming up, if you have movement at the exhaust valve, you are 360 out on the crank and need to go around another full turn of the crank once you have the timing mark on 10 deg btdc No 1 COMPRESSION stroke, take of the dizzy cap, ensure its pointing towards No 1 lead. If its 180deg out, you can redo the leads as a quick fix, or retime the dizzy, normally the rotor button will point towards no1, but you can set it where ever you like, as long as the cap and leads line up with it. I have seen people driven to despair by this, flooding engines, destroying starters, new cams and batteries trying to get them to fire. if you have the spark 10 deg BTDC on the correct stroke, pour fuel down the carby...it will run. |
10-02-2018, 11:54 PM | #9 | |
Junior Member
10-02-2018, 09:29 PM | #10 | |
Junior Member
10-02-2018, 08:15 PM | #11 |
I wonder if the accelerator pump is squirting. If not, no gas yet, or gummed up carb.
10-02-2018, 08:30 PM | #12 |
Moderator
Back to basics....
Remove the spark plug for cylinder #1... Have an assistant bump the key while you have your thumb over the spark plug hole... You will feel compression pressure start to build up in the cylinder...stop and turn off the key.... By hand , turn the crank pulley until the timing mark on the crank pulley is aligned with the 10 degree mark on the timing tab... Remove the distributor cap...the rotor should be pointing at cyl #1 distributor cap post..if its not, rotate the distributor to get it to be lined up... If it is not possible to align, remove the distributor and reinstall with correct clocking... Most backfires occur when distributor is 180 ot of phase...firing 6 instead of 1... Let us know how you go...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-02-2018, 09:23 PM | #13 | |
Junior Member
10-02-2018, 09:25 PM | #14 |
Junior Member
