Old 10-03-2018, 05:57 PM   #1
Bonello711
1962 straight 6 not running issues
Hey guys, I'm not only new to old trucks, I'm also new to turning a wrench. My 62 Straight 6 was running fine until I installed a new stereo, carpet and seat. I can't believe I messed anything up but it now it barely runs at all. It starts on full choke but runs very rough. It won't run at all when I push the choke in unless I stay on the gas. When I get rolling is won't go over five mph and continues to stall.
(was told to check the fuel filter element on the fuel line going into the carb but mine doesn't have one. I also have a newer fuel tank and hardware with a new in-line fuel filter)
Need Help Please... Any suggestions would be appreciated.
Bonello711 is offline   Reply With Quote
Old 10-03-2018, 06:49 PM   #2
Bonello711
Re: 1962 straight 6 running issues
Old 10-03-2018, 07:43 PM   #3
Clyde65
Clyde65's Avatar
When did you move the tank?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-03-2018, 11:13 PM   #4
'65 chevy lover
Sounds like the carb has trash in it. Pull the inline filter and see if it has stuff in it.
'65 chevy lover is offline   Reply With Quote
Old 10-04-2018, 03:37 PM   #5
Bonello711
I tried that first and the inlet looks clear. I also sprayed inside the carb with cleaner and checked the inline fuel filter.
Old 10-04-2018, 07:39 PM   #6
'65 chevy lover
The thing that makes me think it's carb related is that it has to have full choke to even start and then staying on the gas for it to run. Can you pull the float bowl, or did you already do that?
Old 10-04-2018, 10:31 PM   #7
andyh1956
It's the Carpet.
andyh1956 is offline   Reply With Quote
Old 10-05-2018, 10:36 AM   #8
Bonello711
I actually would have tried that first but there's not one.
Old 10-04-2018, 03:36 PM   #9
Bonello711
I never moved the tank.
Old 10-04-2018, 04:32 AM   #10
vince1
Ignition problem? Condenser? What does the spark look like? What wiring changes did you do?
vince1 is offline   Reply With Quote
Old 10-04-2018, 03:49 PM   #11
Bonello711
I didn't do any wiring changes. I never changed anything electrical and the photos show how I bought the vehicle and again, it was running fine and overnight is just started having issues.
Old 10-04-2018, 05:45 PM   #12
Llay R. Rac
Llay R. Rac's Avatar
when my 292 goes from running good, to not so good, the first thing i check is the points.
usually cleaning or adjustment restores smoothness.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 10-04-2018, 06:39 PM   #13
Bonello711
Thanks, I'll start there.
Old 10-05-2018, 09:18 AM   #14
jchav62
1962 C-10
jchav62's Avatar
I agree with it being a fuel/carb related issue. Sometimes a good whack with a screwdriver handle or a wrench is all it needs. Might have a stuck float or junk. Give it a shot...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-05-2018, 10:35 AM   #15
Bonello711
I'll try that, thanks.
