10-16-2018, 09:36 PM | #1 |
what is the best
way to remove the clutch pedal from the swinging pedal assembly? I.m changing my truck to auto and want to remove the clutch pedal and also add a wide brake pedal or at least the wide pedal foot part
10-16-2018, 11:05 PM | #2 |
Who Changed This?
Re: what is the best
The automatic transmission equipped trucks use the same pedal as that in the manual transmission trucks, as far as I know. I'd be interested in seeing what you end up with. But I won't be replacing mine.
10-17-2018, 12:04 AM | #3 | ||
The Older Generation
Easiest way is to remove the whole assembly as far as I'm concerned..... Posted by Member "Palallin": Quote:
10-17-2018, 01:12 AM | #4 |
Blow torch, unless of course you might want to go back in the future.
10-17-2018, 07:51 AM | #5 |
I have the whole pedal box out should have made that clear. My first thought would be cut the pedal of close to the top then tack it at the stop so it can't cause a rattle. Yes I know that the brake pedals are the same for both auto and man trucks I just thin k the wider brake pedal would look better
10-17-2018, 10:19 AM | #6 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-17-2018 at 10:25 AM. |
10-17-2018, 05:36 PM | #7 |
Lock Doc that is what I did. Once it was out I ground the pedal where it is welded on from the back side. I had several boxes from the 99-02 C1500 laying around so I cut the pedal off that brake arm and welded it to the brake arm in my 70 pedal box. I will be doing all of my trucks like this when I get to that part of the build. i really like the way the bigger pedal looks even though it is just the box assm sitting on a table
10-17-2018, 06:11 PM | #8 | |
Good deal. Glad it is working out for you. LockDoc
10-17-2018, 09:18 AM | #9 |
Would it be possible to grab a wide pedal (possible whole assembly) from a later year truck? Not sure when they went to the wide pedal. Might even be able to sell your pedal box to someone looking to do a manual swap.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
10-17-2018, 09:34 AM | #10 |
I haven't compared on the trucks, but on the B body cars it's the same pedal box with a different pedal hanging in there, so all you need is the right pedal and maybe a spacer.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-18-2018, 02:07 AM | #11 |
My clutch pedal was already removed when I got mine - the brake pedal and arm still attached as stock. I wanted the larger pad, so I went with the Lokar and I really like how it looks.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
