Old 10-17-2018, 09:28 AM   #1
SunSoaked
SunSoaked's Avatar
Trans-tcase removal
Anyone have a suggestion on the easiest way to pull them? Split them and drop separately or together? Don't have a lift but I do have a trans Jack and motorcycle lift that fits under my truck.
SunSoaked is offline   Reply With Quote
Old 10-17-2018, 10:12 AM   #2
sweetk30
sweetk30's Avatar
Re: Trans-tcase removal
motor cycle lift should spread it out better . then some good blocks of wood to level it out . and a few ratchet straps to secure it down . and its going to want to roll to the side the front output is on cause of the weight over there .
if its a older truck with floor hump that can be unbolted some guys have had good luck with engine hoist threw the door open and lower/lift it this way .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-17-2018, 10:38 AM   #3
SunSoaked
SunSoaked's Avatar
Thanks. So remove them as one unit?
Old 10-17-2018, 01:44 PM   #4
SBTork
Garage wrench
SBTork's Avatar
If it were me doing it by myself, like it was when I did a few months ago on my K5, I'd do them seperate. In my opinion it's much easier to manage each of them by themselves. I just had a regular floor jack and some wood blocks, it worked just fine.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-17-2018, 01:46 PM   #5
mongocanfly
mongocanfly's Avatar
That's gonna be alot of weight in one chunk...not to mention it'll be awkward and lopsided...without a good working surface and good lifting equipment, I would split them apart...much easier to handle
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-17-2018, 09:48 PM   #6
SunSoaked
SunSoaked's Avatar
Got the T-case out this evening. It wasn't too bad; took about 45 minutes. I have a feeling putting it back in is gonna take 3-4 times as long thanks to gravity. Tommorow I'll pull the trans. Seems no matter what, your gonna end up with trans fluid all over the place. I could tell by the look on my wifes face she wasn't impressed with the mess on the driveway.
Old 10-18-2018, 09:36 AM   #7
andyh1956
Turn the Gravity "Off" before you start back together!
andyh1956 is offline   Reply With Quote
Old 10-17-2018, 10:07 PM   #8
mongocanfly
Haha...just tell her some purple power will clean that tranny fluid right up
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-18-2018, 10:13 PM   #9
SunSoaked
SunSoaked's Avatar
Got that some ***** out! Actually it wasn't too difficult especially with that motorcycle lift. It's off to the tranny shop tomorrow for a performance rebuild. That lift doesn't work worth a **** for my motorcycle but it worked damn good for the trans. I'm gonna bolt everything together and see if there's a balance issue before installation. The wide base and lifting surface may be stable enough that it stays put long enough to get it up and get the bellhousing and x- member in place.
Old 10-19-2018, 10:03 AM   #10
sweetk30
sweetk30's Avatar
even if you bolt it together just use a reg jack under the pass side of the t-case to balance it.
and have the trans shop upgrade the accumulator piston from the plastic to the older aluminum version if they dont already do this .
Old 10-19-2018, 10:08 AM   #11
SunSoaked
SunSoaked's Avatar
Will do. Thanks for the info.
