10-23-2018, 09:17 AM | #1 |
GMC headlight upgrade issues
I originally posted this in ELECTRICAL but got no response so I'll try it here.
I recently upgraded the headlights on my 68 GMC with the Hella 002850811 kit (https://www.amazon.com/HELLA-0028508.../dp/B001G7A9YS). I only changed the outside two lights and I did not upgrade the wiring or add relays, though I plan to someday. The improvement over the old lights is very noticeable but I have one issue. When driving with the brights on the lights will intermittently go off for a split second. It varies from a flicker to going completely dark for a full "Mississippi." It never did this with the old lights and it still doesn't do it when on dim. Last night I made a test drive and kept one eye in my side mirror to see if the side markers flickered when the lights did but they did not. It's not a daily driver so I'm not going to drive it at night until I get this fixed. Any suggestions will be greatly appreciated. Jeff |
10-23-2018, 10:05 AM | #2 |
Re: GMC headlight upgrade issues
I don't know what the load is but the headlights are driven through an auto-reset breaker that I bet you're tripping. You need a proper relay in there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-23-2018, 11:59 AM | #3 |
^^^^^What he said^^^^^
Those headlights pull more amps than standard ones, overloading the circuit. Install a proper headlight harness with the relays. This will power the headlights right off of the battery, not through the headlight switch. |
10-23-2018, 07:28 PM | #4 |
10-4. I've got the relays on order. Thanks for the advice.
10-23-2018, 08:24 PM | #5 |
10-23-2018, 09:11 PM | #6 |
What wattage H4 bulbs did you use? Standard H4s are 55/60W and can go much higher. I believe the stock were closer to 35W. The higher wattage would trip the breaker.
1972 GMC K2500 Super Custom Matt |
10-23-2018, 11:58 PM | #7 | |
20' Daredevil (Ret)
OP, you might consider upgrading the inner (high beam only) lamps to E-codes also. These Hellas use H1 bulbs and being dedicated high-beams, should easily outperform your H4s, which have to perform the separate duties of low beam and high beam. http://www.rallylights.com/h5001-hel...dlamp-kit.html Google might find others (I didn't look). I would stick with an established European brand with proven quality, such as Hella or Cibie.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-23-2018, 10:35 PM | #8 |
So there were auto-reset breakers in 68 in the headlight circuits of GMC?
10-24-2018, 11:15 AM | #9 |
This is what I have on order: https://www.classicindustries.com/product/mx01133.html
11-08-2018, 05:27 PM | #10 |
The first harness that came in was incorrect. Even though the packaging said "4 headlights" it was actually for a 2 headlight set up. Classic Industries promptly sent the correct one and I spent a little time the last couple nights installing it. It did indeed take care of the problem. I drove about 5 or 6 miles last night and did not see even a flicker. Now I just need to spend a little time getting the lights aimed a little better and all will be good in the headlight department. Thanks for all the help.
11-09-2018, 01:12 PM | #11 |
Old member
I have installed several head lights with the relays installed and all I'm going to say is no matter what anyone else says... always, always install the relays.
The relays will take the amps off the whole system and make everything last longer. Even if you install a brand name wiring harness install the relays.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
