![]() Join Date: Mar 2018
I cannot find my axle code
I have looked for my axle code everywhere but need some help with ID.
Axle stamp says HB 0509 Casting stamps 67880 and 12345 12 bolt 1968 C 10 Looking for what ratio is and open or limited carrier without pulling cover off. Thanks Rick |
Re: I cannot find my axle code
I know you don't want to hear it, but the best way to check your ratio is to pull your cover. It's 50 years old & may have been changed at some time & it never hurts to service the diff.
If I'm right HB = 3.07 ratio (but I could be wrong!) |
![]() Join Date: Sep 2017
If the fill plug is recessed on the housing then it is an open carrier.If the fill plug is protruding from the housing it is a posi/limited slip.If the SPID is still in your glove box and rear end ratio is not noted it should be 3:08
hope this helps
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
Thanks for the info. I thought it was a 3:08-3:07 but wasn't sure. But when I did my dash tach it says that at 60 MPH I am at about 26-2700 RPM. I have a TH-400 with 31/10.5/15 tires. With this combo that seems like a lot of RPM's. I am going to pull the cover this weekend to verify. My tach may be off.
Rick |
Might be tach.
You should show a little over 2000 rpm. http://www.advanced-ev.com/Calculato...Size/?speed=70 |
Thanks Geezer
That's exactly what I need. Calculator says close to 4:10 with my set-up and a fairly healthy 350 on a hot day I can hardly spin a tire on asphalt. But it will cruise all day at 75 mph so I am leaning toward 3:08's and tach off. Thanks Rick |
#7 | |
The Older Generation
B. W. is correct. HB is '67, '68, & '69 3.07. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-02-2018 at 10:56 AM. |
