drive shaft
how do you remove front drive shaft on a 1972 chevy blazer
Moderator
![]() Join Date: Jun 2017
Re: drive shaft
You will get more responses if you post this on the Blazer site....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Re: drive shaft
un bolt it, maybe jack the frame up to get clearance, don't jack the axle up.
Re: drive shaft
Mine had 1/4 inch 12 point bolts on the transfer case side and are o mutha to unbolt. I used a small box end wrench of good quality and put one of the front hubs in lock position and the other in unlock as well as the case in neutral to move the shaft by hand. Then when you get you bolt exposed, lock the other hub and unbolt, repeat until you cramp up! haha! If I have to do it again I will swap the front flange to a nut and bolt type and never look back. I thought of this right after I sold a t-case with that flange on it. DOH!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
![]() Join Date: May 2012
Re: drive shaft
Two choices: remove the hump for easy access, or fight with it.
![]() j
White K20 |
