Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-12-2018, 03:05 PM   #1
NewBayColony
NewBayColony's Avatar
WTB 3 Speed Overdrive Transmission
Looking for a Saganaw or Muncie 3 speed Transmission to put behind my 292 3 OTT C20. Thanks
NewBayColony is offline   Reply With Quote
Old 11-12-2018, 09:57 PM   #2
BurbN
BurbN's Avatar
Re: WTB 3 Speed Overdrive Transmission
I have a Saginaw 3-speed w/OD tail shaft unit but it’s missing the solenoid.
Trans worked fine until it got jammed into 1st or 2nd gear, so I pulled it just last year. Since I couldn’t find the parts to get the OD working, and my truck had a 4:11 gear, I had to go with a T5...etc
I live near KC. I have no idea what shipping would cost to MA.
BurbN is offline   Reply With Quote
Old 11-14-2018, 12:25 PM   #3
57Suburb
57Suburb's Avatar
Does your tranny still have the governor in the OD unit?
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 11-13-2018, 03:02 PM   #4
NewBayColony
Thanks BurbN, I'll keep it in mind.
Old 11-14-2018, 08:47 PM   #5
BurbN
BurbN's Avatar
Yes. I PMd you more info.
Those can be bypassed or setup on a push button I believe.
Old 11-14-2018, 09:23 PM   #6
57Suburb
57Suburb's Avatar
Yes, they can, but having them fully functional like GM intended is a pretty slick setup.
Old 11-14-2018, 11:55 PM   #7
BurbN
BurbN's Avatar
I agree. It seems that parts for the OD units are hard to find (individually), so most people want to sell them as a complete setup. Mine will end up in a project someday and function as it was intended, or it will be sold to someone else to do what they please with it.
Old 11-15-2018, 09:05 PM   #8
NewBayColony
I'm still trying to figure out what I want to do about it. I would love to have one working like when it was new.
Old 11-23-2018, 12:59 PM   #9
CRUZN66
CRUZN66's Avatar
Here’s one for sale (Not Mine):
https://classifieds.ksl.com/listing/53993496
CRUZN66 is offline   Reply With Quote
Old 11-23-2018, 01:35 PM   #10
BurbN
BurbN's Avatar
I don’t that one will bolt up to a 230,250,292 block. It looks like it’s made for the earlier 235 engine maybe...
Old 11-24-2018, 10:39 PM   #11
whateverpratt
That muncie trans pattern is the same on the 235 bellhousings and the 194 230 250 292 bellhousings. Bell to trans=the same. Bell to motor=different
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
Old 11-24-2018, 11:20 PM   #12
BurbN
BurbN's Avatar
So he would just need a 194-230-250-292 BELL, if he bought this trans....Good Info.
I think he would also have to make some custom shift linkage, though, because those shift shafts are closer together than the Saginaw 3-speed.
Old 11-24-2018, 11:44 PM   #13
whateverpratt
Yeah, depends on the year I think. At one point the 3 speeds went to a different side cover . 4 bolt to 7 or something. I’m not sure when. My ‘63 had the smaller side cover from the factory.
Old 11-24-2018, 11:49 PM   #14
cwcarpenter98
cwcarpenter98's Avatar
55 to either 65 or 66 were the 4 bolt side covers, technically the muncie sm319 trans.
When GM changed over to the fully syncro'd Saginaw trans with the 7 bolt side cover, the OD version switched over as well
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-28-2018, 11:38 PM   #15
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I little too far from you.
https://salem.craigslist.org/pts/d/m...760210308.html
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-11-2018, 11:33 AM   #16
NewBayColony
Thanks lostmy65. I bought that one and had it shipped. The owner was great to deal with. Thanks again.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
