11-19-2003, 08:33 PM | #1 |
Blazerless:-(
Info or pics on blazer back seatbelts
I am going to install my seat belts, but I can't find a pic of how these attach for the back seats. I know they attach to the 4 seat brackets behind the seat, but do they attach in point "A" or point "B"???? And do they attach the same on each side of the belt (male and female)?
Thanks- Diane |
11-19-2003, 09:10 PM | #2 |
PROJECT 7DEUCE
Both on mine attach to point a. Two belt's on each bolt,but I only put them that way because that's the way I took them off.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-19-2003, 09:29 PM | #3 |
Blazerless:-(
Frenchblue72--Two belts on each bolt? I have 4 brackets...Is the back seat set up for 3 seat belt sets, or just two? Thanks!
11-19-2003, 09:36 PM | #4 |
PROJECT 7DEUCE
I have 3 belt sets' 2 attach on the very end of the seat under somesort of covering? while 2 attach to point a on each side of the seat need a pic??
11-19-2003, 10:09 PM | #5 |
We have two 72 seats that are set up like Frencblue72 described. The outside male belts bolt to the ends of the seat and have a flap over them. Two female belts bolt to the left inner rear support, and one male/female belt bolts to the right inner rear support. The outside supports have no weld nut in them.
The 71 seat that I am shipping to Mark is set up the same as the two 72's. I am not sure if that is a 70's setup that you have and that is why you have four supports with weld nuts on them. Does your seat have a location on the ends for belt attachments? Jim |
11-19-2003, 10:49 PM | #6 |
Blazerless:-(
This is a full pic of my seat brackets- all of them have the bolts for seat belts?? I think I am more confused than ever!
11-20-2003, 02:23 AM | #7 |
SKINNY TIRES RULE!
Some of the rear seats only have two rear mounting brackets and some have 4. You should bolt your belts to the "A" point. I have never seen a rear seat with three belts, but that doesn't mean they don't exsist. Chevy wasn't exactly consistant in this era.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-20-2003, 05:46 PM | #8 |
computer illiterate
the seat i just got has the 4 brackets like yours and it has 2 sets of belts on it and they where bolted in location a
72 2wd blazer 72 swb 4x4 |
11-25-2003, 11:20 AM | #9 |
Mike
My seat has nuts in the 2 outside legs.My seat doesn't even have center legs!It has one seat belt that goes all the way across.It is the original seat.I am the second owner.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
11-25-2003, 01:02 PM | #10 |
Blazerless:-(
Smokekiki- One seat belt that goes all the way across? Do you mean it only has one set of belts for ONE person on the whole back seat? If so that is definately wrong. I think the 71/71 rear seat came with only 2 legs, but I may be wrong. Do you have any pics? Also the bed of the blazer has factory bolt in spots for the middle two brackets on my blazer. How about a 71/72 blazer?
11-25-2003, 01:10 PM | #11 |
Mike
It has 1 seat belt.It is long enough to go from the left side to the right with 3 people on the seat!It has the GM tag on the belt and GM on the buckle.There is no where to attatch belts in the center section of the seat.I can't post pics till next week.
11-25-2003, 08:52 PM | #12 |
Blazerless:-(
My blazer didn't come from the factory with seat belts. I bought it from the original owner who told me he bought all the seat belts from the dealership and paid a OUTRAGEOUS amount to have them install them. They installed them wrong! I am just trying to find info on the "right" or "factory" way to install them. I am pretty sure one seat belt all the way across the back seat is wrong tho'. I think the back seats had 2 sets in all the years.
Diane |
11-26-2003, 09:47 AM | #13 |
Mike
I will try to post a picture next week.It even has the proper date code on the belt.For what other reason would there be a seat belt that long?When dealing with GM products built before 73 nothing is set in stone.With the right person ordering the vehicle,GM would do a lot of off the wall things for You,not like today.
11-26-2003, 01:22 PM | #14 |
SKINNY TIRES RULE!
Wow, one belt is crazy. I wouldn't doubt it though. Seat belts weren't considered as important back then as they are now. The seat I bough only has the two legs and their is no place to mount a belt. I was going to use the four lets (my bed has mounting points for all four) to mount the belts to but only the outside two will be attached to the seat.
