Old 11-15-2018, 01:33 PM   #1
chewychevy67
Can 2.5 center drop manifolds be used on a SBC 2wd?
My 327 engine build has changed direction a bit and now I'm looking to do something a little more peppy. That being said I need more breathing. Any of you guys successfully used 2.5" ramhorns on your 67 72 2wd trucks? Any starter issues? Post pictures if you have please?
chewychevy67 is offline   Reply With Quote
Old 11-15-2018, 02:38 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Can 2.5 center drop manifolds be used on a SBC 2wd?
I am ,There is plenty of room these are 2 1/2 " . You'll have to take it to a muffler shop for pipes I'm sure there is no kit that would bolt up , this is with the engine bolted into the front 350 position Not sure about if it was bolted into the L6 spot ?
Old 11-15-2018, 02:42 PM   #3
chewychevy67
I am having a whole new exhaust put on at a shop so that's not an issue. I see that's a 67 frame too just like mine. That's good to know. Thanks for the pics
Old 11-20-2018, 11:27 AM   #4
chewychevy67
Next question is will I be ok if I drop from 2.5 manifolds to 2.25 pipes? I was initially going to run stock 2" manifolds and go to 2.25"pipe but not sure if I want to choke it out the manifold. I really don't want 2.5"pipes all the way back. Guess I should add that my 327 will Be running aprox 330 hp at the flywheel.
Old 11-20-2018, 03:10 PM   #5
Mike C
Mike C's Avatar
Why not go 2 1/2" all the way?
Your motor is approximately the same setup I have in my Jimmy. .030 327 with forged pistons using a large journal crank in a 4 bolt 350 block. 64cc heads so about 9.5:1 compression. Crane Energizer 266 cam (210 @ .050 .440 lift). Weiand 8004 intake with a JET stage II Q-jet and a small cap MSD ready to run distributor.
I replaced a set of Heddman headers, 2 1/4" exhaust system and some cheapie turbo mufflers with teh 2 1/2" 'vette manifolds, 2 1/2" system that exits 45 degrees to the frame past the rear tires and used the Hemi Turbo mufflers from Dynomax with the 20" case.
Not only is it quieter, It may have even picked up some low end power with no fall-off up high.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-20-2018, 03:22 PM   #6
chewychevy67
Because I have my exhaust pretty much ready to put on. I just bought some 2.5" manifolds because the guy building my engine recommended it over 2" but it wasn't necessary just my call in case I decide to add to my engine in the future. I was thinking 2.25" to keep noise down. At least after the mufflers.
Old 01-28-2019, 11:16 PM   #7
chewychevy67
Hey for you who have Done this did you use a mini starter or a stock size one? Also how hard is it to get to?
Old 01-29-2019, 07:26 AM   #8
shoveldug
Stock starter..............plenty of room
paypal is dwl65101@yahoo.com
shoveldug is offline   Reply With Quote
Old 01-29-2019, 10:17 AM   #9
chewychevy67
Great. I didn't want to buy a new mini starter. Mine is all rebuilt and ready to go. If I had to go that way I would consider going back to the original angled horns.
Old 01-29-2019, 11:23 AM   #10
OregonNed
OregonNed's Avatar
This is an interesting read on manifold that straight drop in a '68, which should be the same as the '67. I was curious about clearance too, and also contacted the author to confirm. For what its worth.
https://www.hotrod.com/articles/1112...engine-exhaust
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
