Old 11-18-2018, 10:24 AM   #1
Noah96
Leaky Glovebox
Got a problem folks, Replaced my windshield new gasket and put a new glove box in and rained one day and had a puddle in my glove box looks like the leak is coming from the back right corner off the glove box looking in. Any idea of how to fix this anyone?
Noah96 is offline   Reply With Quote
Old 11-18-2018, 11:01 AM   #2
geezer#99
geezer#99's Avatar
Re: Leaky Glovebox
Easy fix!
Put a drain hole in the glove box! JK! LOL!!
Your new windshield gasket is no good.
geezer#99 is online now   Reply With Quote
Old 11-18-2018, 11:09 AM   #3
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: Leaky Glovebox
When I had my windshield replaced in my 81 C10 the glass installer advised me that it takes a few days up to a week for the gasket to properly seal and that leaks were a possibility.
If it is a week past that time I would recheck the gasket to see if it is bad or not properly sealed.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 11-18-2018, 11:29 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Leaky Glovebox
Try using a little windshield sealer 6" in from the top corners and 3" down from the top corners of the windshield gasket. That may help the leak problem. Also check the inside of the drip rail and the seam below it and chalk as necessary.
The glove box liners have a seam on both sides and the lap in the seam is open at the top, so any water that leaks on the top of the liner runs down into the glove box. You can see what I'm talking about in the picture below. I always use sealer to seal up the gap in the seams before installing the glove box liners. I use a product called DAP tub & tile chalk. You can get it at any hardware store.
LockDoc
Leon
Old 11-18-2018, 11:09 AM   #5
custom10nut
custom10nut's Avatar
Re: Leaky Glovebox
Is it your windshield gasket or the body seam? I don’t have any tips for you but mine leaks through a seam where the filler has come out ( i haven’t got to fixing it yet ). If water gets through the seam, it follows the post down to the dash, or wherever gravity takes it. Mine will leak more if I park slightly “ nose down”
custom10nut is offline   Reply With Quote
Old 11-18-2018, 11:57 AM   #6
GMCPaul
Re: Leaky Glovebox
GM specifies in the factory service manual to use weatherstrip cement under the entire perimeter edge of the windshield seal, the seal alone isn't meant to be watertight without it. The recommendations on checking seam sealer are also appropriate, check the windshield upper drip rail, and remove cowl and check seam sealer ant base of windshield, while doing so check all cowl seam sealer as 40+ years causes it to dry out, shrink, become brittle and break off leading to leaks from missing seam sealer.
Paul Sr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 11-18-2018, 12:14 PM   #7
davepl
davepl's Avatar
Re: Leaky Glovebox
Yup, windshield is supposed to be cemented into place in order to be weathertight.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-18-2018, 02:28 PM   #8
Noah96
Re: Leaky Glovebox
Thanks everyone its been a few weeks was replaced but im going to take a bucket of water with me and see if I can pin point the leak and patch with sealer.
Old 11-18-2018, 02:55 PM   #9
slikside
slikside's Avatar
Re: Leaky Glovebox
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 11-19-2018, 06:47 PM   #10
Noah96
Re: Leaky Glovebox
Well think Ive fixed the problem? months ago I removed the antenna wire and the whole left was causing water to leak in.Name:  IMG_2283.jpg
Size:  48.5 KB Some roofing tar along with something to fit over the whole perfectly.
Old 11-19-2018, 08:09 PM   #11
toolboxchev
Re: Leaky Glovebox
Well think Ive fixed the problem? months ago I removed the antenna wire and the whole left was causing water to leak in.Attachment 1840000 Some roofing tar along with something to fit over the whole perfectly.
If you used PGW Glass and bought your seal there, I would be almost certain it is a Precision Gasket. Those are the good ones.
toolboxchev is offline   Reply With Quote
Old 11-19-2018, 10:17 PM   #12
57taskforce
All about them K’s
57taskforce's Avatar
Re: Leaky Glovebox
I do believe the seam to the right of your quarter is supposed to be full of seam sealer. The two trucks I have had both had factory sealer there, you can see what’s left of it below your windshield gasket. I actually just resealed my K20.
Tyler
Old 11-19-2018, 07:37 PM   #13
demian5
demian5's Avatar
Re: Leaky Glovebox
Also, the upper corners can leak. Its common to fold back and put windshield silicone in there.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
