Old 11-20-2018, 05:50 PM   #1
karlbenz
trans swap ??
I have an 84 k10 chassis. 383 stroker. 700r4. np208. I have a good th400 out of a 2wd I would like to put in and use my np208. It's my hunting truck, no real serious abuse. lot of mud though. What do I need to do this swap? this is low budget, I'd like to stick with what I got. Thanks
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 11-20-2018, 06:40 PM   #2
sweetk30
sweetk30's Avatar
Re: trans swap ??
if your 700r4 works fine just leave it alone . keep it good and cool and happy .
swapping out for the th400 might = driveshaft length changes . but more important the 700r4 is 27 spline output and the th400 is 32 spline . so the np208 input gear will need to be swapped or find a good t-case setup for 32 spline input . the adapter is also going from a 4 bolt trans side to a 6 bolt . so you will need that . last but most important is the length and style of the th400 output shaft . there was 5-6 good comon used ones . some 2wd can be used on 4x4 some cant . the th400 also needs the gas pedal mounted kick down switch added for the passing gear . lots of trucks have the pedal braket setup for it . you just need the 40-50 bucks new switch on popular auction sites onlinE ( hint hint E ) and some wire and a bolt to hold it on the bracket .
and the 700r4 has that low first gear the th400 dosn't have it . so after the swap it might feel like a dog off the line .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-20-2018, 07:52 PM   #3
karlbenz
Re: trans swap ??
the shaft sticks out 4.5"
1965 Chevy C60
Old 11-20-2018, 07:52 PM   #4
karlbenz
Re: trans swap ??
is there a better option for a transfer case?
1965 Chevy C60
Old 11-20-2018, 07:59 PM   #5
sweetk30
sweetk30's Avatar
Re: trans swap ??
i my self dont like the 208 . there a bit weaker than the 241 . this would take the same shifter so no swap there . there in around 87ish - up trucks / blazers / suburbans still with the solid front axle pass side drop .
or find a 205 cast iron gear to gear . but thats a different shifter setup and less low range crawl ratio but a tank of a t-case .
found this for ya off my other old computer.
