11-23-2018, 07:26 AM | #1 |
Will this tire/wheel size work
I know there are a million threads on this and I have gone through them all. I have done measurements on my truck but I just want to double check with them masses.
I have a 5/7 static drop. Will this tire/wheel combo fit? Thank you in advance Paul Front: 8.5x20, Tire: 255/40R20 Backspacing: 5.25" or 8.5x20, Tire: 255/45R20 Backspacing 5.25" Rear: 10x20, Tire: 295/40R20 Backspacing: 5.5" or 10x20 , Tire: 305/45R20 backspacing: 5.5" I would prefer to us the 305 tire in the rear if it will work. Please let me know from your experiences. Thanks |
11-23-2018, 11:25 AM | #2 |
Re: Will this tire/wheel size work
I'd say they should fit. I'm running the same size wheels, with 245/40 in the front and 315/35 in the rear. I don't think there would be any issue going to a 255/40 in the front. Not sure about a 255/45 though, that might be getting too tall. For the rear, 315 is as wide as I'd go but taller shouldn't be an issue. A 305/45 is over 2" taller than a 315/35 though.
245/40ZR20 and 315/35ZR20 fit my truck with a 5/6 drop without rubbing anywhere.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 |
11-23-2018, 11:27 AM | #3 | |
11-23-2018, 09:47 PM | #4 |
Same backspacing as you want to run, 5.5 rear, 5.25 front. I haven't had to make any adjustments to the fenders to get them to fit.
11-24-2018, 10:02 AM | #5 | |
1.How much room do you have between the tire and the fenders front and back? 2. Do you think it would be possible to run a 5" backspacing in the front with a 255/40? Thanks for you insight. Paul Last edited by 44boggers; 11-24-2018 at 10:08 AM. |
11-24-2018, 02:08 PM | #6 |
The rear is about an inch from the outside sidewall to the fender, and less than that, maybe 3/4 of an inch from the inside sidewall to the fender.
The front has more room. Probably an inch and a half on the outside, and lots on the inside. It's tough to measure because I don't have a way to get the truck off the ground to get underneath it. I think a 255/40 probably would fit with a 5" BS. I think there's room there to take the 1/4 inch of backspacing and the 10mm of extra tire. I don't know though. The only reason I went with 245/40 in the front was because that's all that was in stock at the time. I ordered 275/35 but they didn't come, and we weren't sure if they would fit anyway. So we put the 245s on. Next time I think I'll try a 275/35 though, and I might go down to a 305 in the back.
11-28-2018, 09:59 PM | #7 |
This may help some
12-01-2018, 08:51 AM | #8 |
And another
