11-27-2018, 09:28 PM | #1 |
1971 5.5/7 drop with 20x8
Is anyone running 5.5/7 drop with 20x8 wheels? I am trying to see if they will fit or if I should go 4.5/6 to fit 20x8.
Also, not sure if this is a suspension or tire question or both so I decided to post here first. |
11-28-2018, 08:31 AM | #2 |
67-72 parts collector,…
Re: 1971 5.5/7 drop with 20x8
It all depends on wheel backspacing and total tire height.
Try to keep the tire height at 26"-27" and you should be able to run stock inner fender. If I was running a 20x8 wheel up front,... I would use at least a 5" backspace.
11-28-2018, 11:27 AM | #3 |
Thanks for the input! I'll keep digging around a bit to see if I am going to commit to 20 or just run 18.
11-28-2018, 12:32 PM | #4 |
I like 20's up front.
Run a 245/40-20 tire and you'll be set. I like 255/40-20's on a 20x8.5 wheel.
11-28-2018, 03:00 PM | #5 |
That was the tire size I am eyeing right now, and possibly 295/40/20 for the rears. I am just slightly worried about rubbing in the front on the fender liner.
Your old rig looks like the stance I am going for! Nice work! |
11-28-2018, 12:34 PM | #6 |
This is my old truck the member n2billet has now.
20x8 up front with a 245/40 Approximately 5.5/7.5 drop.
