Old 11-29-2018, 09:33 PM   #1
chris989
class 5 hitch
hello all,
I was going to upgrade my hitch on my v2500 to a class 5. I occasionally will need to tow a track loader. It and the trailer will weigh ~12k.
Is there any reason a hitch for a 1980s C/K3500 would not fit? How different are the frames? I am using k3500 springs on my v2500 and they were bolted right in.
https://www.etrailer.com/Trailer-Hit...cc-onlyreviews
https://www.etrailer.com/p-BWHDRH251...model=Suburban
chris989 is offline   Reply With Quote
Old 11-29-2018, 10:15 PM   #2
sweetk30
sweetk30's Avatar
Re: class 5 hitch
12k is a BIG load buddy .
rear end of the frame is basically the same on 1/2-1ton trucks . if suburban or blazer thats a whole different frame setup not the same end rail style .
yes you put bigger springs in your 3/4 ton but the frame is still 3/4 ton size .
also the brakes are prob a lot smaller over the 1ton rears and the front for sure are smaller .
last better check the local laws on towing limits and specific plate / insurance / even driver lic requirements the caps are starting to crack down all over on the little guys now .
also in the 12k range you would be much better off with a gooseneck trailer / hitch . spread the load out better and haul a lot nicer for you . no massive end of the frame tongue pressure killing the ride .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-29-2018, 10:29 PM   #3
mongocanfly
mongocanfly's Avatar
Re: class 5 hitch
/\/\...what he said...I pull 9k loads with my 1ton....couldn't imagine 12k on the bumper...dot would have a field day with that
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-30-2018, 11:54 AM   #4
chris989
Re: class 5 hitch
thanks,
