12-03-2018, 04:38 PM | #1 |
Active Member
Amp powerstep install with pics
I finally installed the power steps. My truck didn’t come with the door jamb switch, so I ordered the switches, door jamb switch harness and courtesy light harness.
12-03-2018, 04:44 PM | #2 |
Active Member
Re: Amp powerstep install with pics
These switches should self adjust , but I don’t think they adjusted at all. Anyway this is the drill bit and threader I used. I know it says self tapping but didn’t want any loose switches, I had no problem at all installing them.
12-03-2018, 04:48 PM | #3 |
Active Member
These are the power steps I bought. Got them off of EBay, they were a brand new kit still in factory packaging.
12-03-2018, 04:56 PM | #4 |
Active Member
This is how I hung them from the bottom of the cab.
12-03-2018, 05:00 PM | #5 |
Active Member
Next was the harness, pretty easy. Negative and positive wires connected the battery terminals. Trigger wires connected to the door jamb switch to activate the power steps.
12-03-2018, 05:04 PM | #6 |
Active Member
These steps made a big difference, they come down about 8 inches. My truck has a 4 inch suspension lift with 35 inch tires.
12-03-2018, 06:14 PM | #7 |
Thanks for posting, they look nice and this is the most functional step out there and they hide away fairly well. A member on the 99+ forum installed them and also shortened them to regular cab length - something I’m looking into for my 01. You can rotate pics by editing on your computer or editing on your iPhone - all have a rotate function - just resale them and reload.
12-03-2018, 06:43 PM | #8 |
Here you go......Great job, well done.
12-03-2018, 10:05 PM | #9 |
Beautiful truck and nice write up, if I ever get a 4x4 those will be a must.
12-04-2018, 08:11 PM | #10 |
awesome job on the steps, how much were they if you dont mind saying?
12-04-2018, 11:24 PM | #11 |
Active Member
Jocko, that’s what I did today, cut the boards down to the length of the cab. El Dorado Jim I paid $500 with free shipping. I had been looking for a set for awhile.
12-04-2018, 11:48 PM | #12 | |
Btw, $500!!!!! Where on earth did you find em for that price? I thought they were around $12-1300? Do tell |
12-06-2018, 01:12 PM | #13 | |
He said in the first post: eBay
12-05-2018, 05:09 PM | #14 |
12-05-2018, 05:46 PM | #15 |
Thanks for sharing Coppertone! That is one cool mod!
I would like to see/know more about how you mounted them to the cab subframe and, it looks like they mounted to the rocker as well.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Tags |
amp power steps, amp research steps, steps |
