Old 12-04-2018, 12:11 PM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Crew Cab Build
There have been alot of crew cab posts lately, here's my rendition. Rather than just welding a truck back onto a burb I am taking the time to go with a more oem approach. Final assembly will be done with a Pro Spot Spot Welder. Due to the differences in the roof structure I think it is actually easier to stretch a truck cab and install b-pillars. But I already have a burb with a trashed back section so I will be doing extra work to put the correct roof structure in it.
This is the rather complicated roof structure of a suburban and why the roof is taller
This truck cab has some of the worst rust I have seen in the roof/gutters. Luckily I dont need that part. It basically peeled off
Windshield removed
The Dash was perfect save for a switch installed in left side so I removed it and saved as well.
With the spot weld cutter warmed up I started tackling the inner roof. My goal is to remove it at the factory joints and save it. Maybe stretch it to go back in or make a new one. Either way I need a starting point.
Top of windshield drilled and removed(it rusted through at sides)
Not sure if this upper A-pillar reinforcement is in the burb. Will find out soon
All drilled. Getting the back loose
With a little wrestling you can get it to this point
Parts Pile. Not too much rust in the inner, will repair
Scalped
Next up will be cutting the upper door jambs, floor and removing the rear section of the cab. Probably pull the gutters as well. You can see here the upper jamb spot welds to the a-pillar section and b-pillar section. just need to make it longer.
Also picked up another burb B-pillar from a member here. Going to disect this one and make patterns to make future B-Pillars. I have some ideas and plans on low-production stamping some of the pieces.
Got a little time to work on the cab again. Cut across the floor and cut the upper jamb pieces loose. I now have the back of the cab rough cut and ready to start fitting to the burb. Post #2 will be the disassembly of the burb clip.
Last image for Post #1. Moved some things around and put the two players in close proximity.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 12-04-2018, 12:12 PM   #2
Bagd72Chevy
C10 Collector
Re: Crew Cab Build
Reserved #1
///Ryan
1971 Blazer - Rusty
Old 12-04-2018, 12:13 PM   #3
Bagd72Chevy
C10 Collector
Re: Crew Cab Build
Reserved #2
///Ryan
1971 Blazer - Rusty
Old 12-04-2018, 12:15 PM   #4
Bagd72Chevy
C10 Collector
Re: Crew Cab Build
Reserved #3
///Ryan
1971 Blazer - Rusty
Old 12-04-2018, 02:50 PM   #5
Getter-Done
Getter-Done's Avatar
Re: Crew Cab Build
I am along for the ride.
Nice work.
84 Chevy K-20
Old 12-07-2018, 04:05 PM   #6
8mpg
8mpg's Avatar
Re: Crew Cab Build
This is going to be a great build. Look forward to the updates.
8mpg is offline   Reply With Quote
Old 12-07-2018, 11:16 PM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Crew Cab Build
As one who has dissected a burb roof during my build, the Burbs do have that a pillar reinforcement.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-09-2018, 09:43 PM   #8
Bagd72Chevy
C10 Collector
Re: Crew Cab Build
Thats great news, thank you. I took a break from it as I had a 'little' deal fall into my lap. Also added some more pictures up top. Burb roof skin removal next.
///Ryan
1971 Blazer - Rusty
Old 12-14-2018, 12:55 AM   #9
rwade
rwade's Avatar
Re: Crew Cab Build
Along for this build too
Wade
rwade is offline   Reply With Quote
Old 12-14-2018, 01:31 AM   #10
Getter-Done
Re: Crew Cab Build
I see your Reason for the Break.
That will help you a lot.
84 Chevy K-20
Old 12-17-2018, 05:29 PM   #11
Bagd72Chevy
C10 Collector
Re: Crew Cab Build
Yes sir! I already have 2 older lifts in the shop but it will be nice to have a super wide 12k now. The other 3 10k's are going to my buddy's. Just need to get the power ran and hooked up.
///Ryan
1971 Blazer - Rusty
Old 12-08-2018, 02:06 AM   #12
1972K20
1972K20's Avatar
Re: Crew Cab Build
Looking good
1972K20 is offline   Reply With Quote
Old 12-09-2018, 03:16 PM   #13
72 tigger
72 tigger's Avatar
Re: Crew Cab Build
Looks like a good start
72 tigger is offline   Reply With Quote
