Old 12-09-2018, 11:09 PM   #1
HSRACER
HSRACER's Avatar
Crazy throttle question
So I have a crazy throttle question for the group.
I have a 5.3 in a 67 stepside that came out of a 03 suburban with drive by wire. The problem that I am having is the transmission downshifts at very light pedal pressure and slight movement from the idle position.
It drives well when you give it slight pedal movement, but when driving it what I would call normal it always downshifts way to early.
After so diagnosis I have found the tps reads 100% at half the pedal stroke. I then pulled elbow off the throttle body and verified the actual throttle plate is wide open at half throttle on my pedal.
My question is can the pedal be calibrated to the throttle plate somehow? I would like to see it work with half pedal equaling half open throttle plate and so on. if it can be done is there a sequence or procedure that you can share with me.
I am just learning the whole LS drive by wire thing and have a friend who is just learning the HP tuner program. We are novices at this kind of diagnosis and repair so be gentle!
Thanks for any assistance you can give.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 12-10-2018, 04:19 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Crazy throttle question
I've seen this happen when a TAC from a truck with adjustable pedals is used with a standard gas pedal. Did you by chance change the pedal?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-10-2018, 09:26 AM   #3
HSRACER
HSRACER's Avatar
I bought the truck as is so I don’t know the history. Are there any numbers I can check?
Old 12-10-2018, 10:47 AM   #4
beaterku
beaterku's Avatar
What was the remedy? My LQ4 came from a denali with adjustable pedals. I am using the adjustable TAC with a standard truck pedal. Haven't finished the project yet. Curious what panned out.
beaterku is offline   Reply With Quote
Old 12-11-2018, 11:48 AM   #5
ls1nova71
ls1nova71's Avatar
I think it needs a non adjustable pedal TAC, but not sure. My buddy never did anything about it, he just got used to driving it that way. I've driven it and it is a bit touchy, but not all that bad once you get used to it. I can look and see what the numbers are on that TAC and what they are on mine, but I don't know when he'll have his car back out again. If you get it going and it has this problem, get a hold of me and I can lend you a TAC to see if it remedies it since you're close.
Old 03-13-2019, 10:12 AM   #6
beaterku
beaterku's Avatar
So I powered up my truck last night to check wiring and noticed that I am having the same problem. My TAC came from the same donor as the engine and ECM. Its #12573059. I bought the GM truck pedal #15264643 that is for the same year Silverado 2500. I am getting full throttle when the pedal is half way down. When I look up the TAC module for a 2003 Silverado 2500 it is showing #12588923.
Were you able to figure out if it was in fact the TAC module causing the problem?
Thanks!
Old 03-13-2019, 10:17 AM   #7
beaterku
beaterku's Avatar
Did some digging on ebay of all places.
Standard truck pedal and comes with #12588923
https://ebay.us/DLsWzk
Adjustable pedal and comes with #12573059
https://ebay.us/fXx2y9
Looks like this may be the solution.
Last edited by beaterku; 03-13-2019 at 11:16 AM. Reason: Added pictures for future help
Old 12-10-2018, 10:39 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Engine->Airflow->Electronic Throttle -> Desired Pedal Area
Take a look at that chart and see when it commands 100%
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-11-2018, 03:00 PM   #9
HSRACER
HSRACER's Avatar
So we just tested my buddy’s 02 suburban with the tax and it performed as you would expect. 40 percent throttle equals 40 percent blade opening.
I guess I will see if there are options for different tax modules
Old 03-13-2019, 10:54 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm sure that'll be useful for some folks in the future. I'm surprised it hasn't come up before, but I'd guess that the # of adjustable pedal GenIII trucks (high model line trucks 04-5) is low in comparison to the overall #. Guys using Denali, Escalade or high-line Yukon/Tahoe's as donors would need to keep an eye on part #'s
Old 03-13-2019, 08:53 PM   #11
ls1nova71
ls1nova71's Avatar
I have some spare TAC modules, so if you want to try one you're welcome to it. I work downtown and get off at 8:30 in the morning if you want to meet me somewhere just let me know.
Old 03-13-2019, 09:44 PM   #12
beaterku
beaterku's Avatar
I’ll shoot you a PM
Old 03-13-2019, 10:18 PM   #13
HSRACER
HSRACER's Avatar
We ended up using hp tuner to modify the tac vs throttle position sensitivity and it worked pretty well. The hp tuner gave us a warning to not mess with this setting as the possibility to lock out the computer existed.
I figured I hated the way it worked so we might as well try it and we took baby steps going forward. We got it to a point that it seemed to work acceptable and we stopped for fear that any more modifications could screw us up.
Drives well now but I may try to see which Module I have and decide if I want to change anything.
HSRACER
Slammed 53 5 window
Old 03-15-2019, 03:01 PM   #14
michael bustamante
michael bustamante's Avatar
i have the exact set up in my 67 stepper as well! and its orange!
mines a 2003 Yukon doner with non adjustable pedals and I don't have this issue but my 13 Silverado with adjustable pedals does... downshifts everyime I step on the gas even a little. looks like im taking it in
1967custom
michael bustamante is offline   Reply With Quote
Old 03-16-2019, 02:33 AM   #15
ls1nova71
ls1nova71's Avatar
Can you post a pic of your pedal and how far it moves? The 13 Silverado shifting issue probably has more to do with the transmission than the pedal, 6l80s shift weird anyway.
Old 03-16-2019, 01:44 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Noticed this on a dealer parts listing:
GM Part No.: 12573059
Module,Electronic Throttle Actuator Control
Part Description MODULE,ELEK THROT ACTR CONT
Replaced By 12588923
Old 03-16-2019, 04:17 PM   #17
beaterku
beaterku's Avatar
Well that is an interesting wrinkle...
Old 03-17-2019, 08:15 AM   #18
72GreenMonster
72GreenMonster's Avatar
Good forensic work on the dbw and TAC challenges.
It is my understanding the 99-02 TAC is also different.
I just bought a 02 gas pedal and TAC on ebay for my 02 tahoe donor 5.3.
Not quite ready to fire up but
curious if it will match up to pcm and my throttle body.
I did find this link which covers LS throttle and TAC differences. Hope it helps
and good luck to all those in TAC school.
https://www.lsenginediy.com/gm-gen-i...uipment-guide/
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
Old 03-17-2019, 01:41 PM   #19
LH Lead-Foot
Using a non-scientific method, I took my HF angle gauge placed it directly over the pivot of my 2003 Tahoe electric adjustable throttle pedal. After 5 tries to get an average, I measure 12 degrees of movement of the pedal. That ain't much and surprised me a little. I would expect to have similar 5 volt signals which would make one think there is not reason to have a different TAC module. But, who knows...we didn't built it.
Seeing the video of the non-adjustable pedal, which appears to be much longer movement, perhaps twice as much. I would guess the APP sensor has major sensitivity over a very short range of motion compared to fixed pedals.
I tried to take photos with some better than others, but burry or too shiny to be worth posting, but still 12 degrees of movement.
If there a two part numbers listed for this particular RPO code w/adjustable pedals, I have no idea unless there is a first design, second design or internal electronics have change. I was told the GM changes the part number with a different supplier, materials, and even the box packaging.
But I would definitely say, there is two TAC modules. One with adjustable pedals and one without.
We have seen many use mis-matched APP sensors and TAC modules use in other builds. Some caused drivability issues, codes or did not work at all on the DBW system that are becoming more plentiful in the bone yards.
My suggestion is with cameras everywhere in phones, but get as shot of the RPO codes (Trucks / SUV's alway glove box door) but VIN as well for programming and future reference.
Newer PCM's include mileage as well, but one can make that up in a swap, but for future swaps, get the VIN and RPO codes...and matched parts.
This has been very interesting find, adding more knowledge to the forum. My personal RPO code book does not go above 2001. I will get mine and look at it soon as I hidden 6 or more in the garage. Still, very interesting...
Removed
LH Lead-Foot is offline   Reply With Quote
Old 03-17-2019, 04:30 PM   #20
72GreenMonster
Tricky, yeah yeah the challenge is between the 2 wire and 3 wire tac module along with the different pedals would love to have a simple solution for plug-and-play
72 GMC Sierra 2500
Old 03-17-2019, 04:31 PM   #21
72GreenMonster
Sorry just one yeah! Voice text error. Not yeah yeah
72 GMC Sierra 2500
