Old 12-12-2018, 10:08 PM   #1
moregrip
moregrip's Avatar
Sport side mirror 101 for $200 Alex
Got a few questions on Sport Side mirrors.....lol, I'm learning I really don't understand the details as well as I thought I did.
Is the mirrored glass replaceable? I have a two edge chips on a mirror and has a slight tick to it as it sits in the housing; see pics:
Also, is this what the factory mounting holes look like on a door? The included hard plastic shim/gasket fits the two mounting holes perfectly and the third hole fits the plastic nub I assume for locating the mirror correctly?
If those are the correct mounting holes, it appears there "may be" left and right specific plastic shims/gaskets because the third hole on the drivers side has the same orientation as the passenger for mounting or are they all the same as shown below?
Thanks for the help!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 12-14-2018, 07:28 AM   #2
moregrip
moregrip's Avatar
Re: Sport side mirror 101 for $200 Alex
update:
1. upon further research it looks like those door mounting holes are useable for sport mirror mounting but there is an inner structure they actually bolt too.
2. it appears replacement glass is available for these mirrors.
3. the plastic gasket looks to be the only type available (that I know of) and I will need to cut the plastic nub of to use it on one of the sides.
Old 12-14-2018, 08:32 AM   #3
Danmcg
Cut off the nub or drill a new hole for it to fit on the opposite side?
Danmcg is offline   Reply With Quote
Old 12-14-2018, 09:26 AM   #4
cruizin01
I cut the knubs off mine to use. I didn't have the brackets for the inside of the door so I used shallow bolts and larger washers with nuts. Worked fine.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 12-14-2018, 07:03 PM   #5
moregrip
moregrip's Avatar
thank you
Old 12-14-2018, 12:38 PM   #6
Dads79GMC
Dads79GMC's Avatar
Chief, the inner supports can be purchased and they provide some inner structure for the mirror. You’re in track Bud! Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 12-14-2018, 12:44 PM   #7
Dads79GMC
Dads79GMC's Avatar
Here you go.
Old 12-14-2018, 07:04 PM   #8
moregrip
moregrip's Avatar
Originally Posted by Dads79GMC View Post
Here you go.
Thank you sir! Excellent excellent!
