making a short story long...
Truck is a '72 350/350 with HEI, newer Holley 4 barrel, stock. It's been running rich so finally got some time and decided to explore prior to putting it to bed for the winter. All the signs of running rich, fouled plugs, smell of gas etc. Started running poorly in the fall, stumbled on accceleration, poor mileage etc so I assumed carb issues and/or timing as well. Must note that I'm no mechanic.
So far I've changed out the in-line fuel filter, Checked the compression (between 120-135), sprayed around and checked lines for vacuum leaks, new plugs gapped at .045, tested plug wires for arcing and double checked firing order. While doing this I gave the distributor a twist and it was very loose. Now I've shifted it and I'm assuming screwed up the timing. It's getting gas, two streams squirt into the primaries when I stroke the throttle, but won't start. Cranks and almost wants to go but won't start. Any advice on next steps would be appreciated.
'72 Highlander '88 GMC Sierra 1500 '14 Chevy Silverado 2500HD Duramax |
Re: making a short story long...
If it ran before you moved the distributor have somebody crank it while you turn it slowly and it should fire. Snug it down once you get it close and get the timing checked or buy a light and learn from YouTube!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
[QUOTE=projectking;8405232]If it ran before you moved the distributor have somebody crank it while you turn it slowly and it should fire. Snug it down once you get it close and get the timing checked or buy a light and learn from YouTube![/QUOTE
Thanks projectking. I do have help this weekend, and your suggestion sounds simplest, so I'll start here.
![]() Join Date: Oct 2011
Ok...(always) start with the timing, not the carb.
Any chance of putting the distributor back to the position from whence it came?....it was running there? If not, then: You need to get the firing set up correctly so you need to pull the #1 cylinder spark plug so you can check the cylinder position. Then you need to crank or turn the engine over to where the #1 piston is at top dead center (TDC). You can tell this several ways...looking at the timing mark on the flywheel is part of it and it should be aligned crank to timing pointer. Also check in through the spark plug hole if the piston is there at tdc...you can use something medium soft to check this. As well, when cranking...you should feel or hear the air coming OUT of the spark plug hole while the piston heads up to its TDC position. With that established, trace the #1 spark plug wire back to the distributor cap and mark on the lower metal body where it plugs into the cap. Remove the cap and see if the rotor is at that position or very close.....ie: would spark be achieved from the rotor to the cap if you reinstalled the cap. This should also immediately tell you which way (rotational) that you have to adjust the distributor to get the rotor lined up with the cap and the #1 wire to get the engine to fire. Ok, I'll leave off there for the moment. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Another note on finding TDC:
Be aware that since this is a 4 cycle engine, the crank spins twice for every rotation of the camshaft and rotor. The #1 piston comes to the top and timing mark lines up to 0 twice for every 1 time the rotor lines up to the #1 position. If the rotor looks to be 180* out, spin the crank around again. Once you get the rotor pointing to #1, make a mark in the intake straight out from where the rotor is pointing. Reinstall the cap and see if this is near #1. You want the #1 terminal on the cap to be at or slightly before the rotor position. I prefer to make a mark on the intake, so I can spin the distributor and line it up if it is not aligned correctly. It is always best to figure out timing first before messing with the carb. With a timing light, you can KNOW where the timing is at. You don't want to tune your carb to cover up incorrect timing. If it was running rich in the summer, it should be running better in the winter. The air is colder and more dense, which causes a leaner air fuel ratio.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Thanks for the fast responses - much appreciated. I love tinkering with the truck and use the search function here a lot but, again, I'm no mechanic. I have turned the distributor back to where it was (close) but working alone I haven't be able to crank while turning. I'll have help this weekend.
Secondly I did pull #1 plug and bumped it until it blew my finger off the hole. At that point the rotor appeared to be pretty close to the #1 terminal. Now, here's where I'm confused, at that point I've found TDC correct? Now I need to find the timing mark on the balancer and rotate it so it lines up with the timing tab, correct?
![]() Join Date: Oct 2009
All good advice above. As long as you didn't remove the distributor (i.e. you just rotated it), the worst you could have done is to mess up the initial timing setting - cam and crank relationship is intact as well as the distributor being installed correctly into the cam gear - so you should not need to find TDC. Projectking's method would be preferred if you have a helper, and Coley's distrib body mark is the way I do it also if doing it by myself. So in a nutshell for me (if working solo), I remove the distrib cap, rotate the crank (by the balancer bolt) until the balancer timing mark is at approx 4-6 deg BTDC AND the rotor is pointing approx to the left headlight quadrant of the truck (may take more than one trip past TDC mark as mentioned above). Twist the distrib body (if required) such that the leading edge of the rotor tip is approx directly above the mark on the distirb body you made), tighten the distrib clamp, reinstall cap, start it up and set initial timing with a timing light. Then worry about the fuel system
Ok I am sure some people will really hate this idea, but it certainly is the easiest.
1) pull a spark plug or 2 from each side of the motor 2) hook up a timing light 3) have a buddy crank it (it will crank faster missing some plugs) 4) set the timing like you would with the car running. It isn’t perfect but it will get you close enough to run. Then set it right. My buddy and I do this as an added insurance policy with new motors to help make sure we don’t get a carb backfire or something on first start up. |
#9 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Once you get the timing done if it still acts up or for preventive maintenance if the original quadrajet is still on the truck get it rebuilt..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#11 | |
sorry about that - I should've just said driver's side - same as if pointing at #1 cylinder. And right taillight is passenger side.
Just an update for all who provided much-needed input. Had some help on the weekend so tried cranking while turning the distributor but still wouldn't start. Sooo close, she wants to fire but just won't go. Anyway, probably shouldn't have started messing with it so close to Xmas - too many things going on. I do have a couple of questions though....
1) while turning the distributor how much precision is involved. Would it not start in one spot and then start if moved 1/4", 1/2" etc? 2) I know I have gas so want to check spark again. What's the best/easiest way to check?
#14 | |
If it was almost starting - it's quite possible you were about in the right spot but had flooded it. If you think this may be the case, pull a spark plug and check it out. Also a great suggestion above to confirm wired correctly for firing order. I bought a car once that I wasted a week of troubleshooting on only to finally figure out it was cross-wired on 2 cylinders (it did start still somehow though!). Worth checking. |
#15 |
Hook your timing light up to any plug wire, crank it over and if the light flashes you know you have spark.
Some motors don’t like to start unless the timing is spot on. |
#16 |
![]() Join Date: Feb 2016
At this point I suggest going through and verifying that all of the spark plug wires are hooked up correctly and that you have 12 volts present at the HEI when cranking the starter.
As far as turning the distributor, 1/4" at the vacuum advance at a time will get you there. If you are in the ball park you shouldn't go more than 3/4" at the most. And if things still are not working throw the old plugs back in and see what happens. Many years ago I installed a set of new Champion plugs and could not get the engine to start. Hours later in desperation I put the old ones back in. The engine jumped to life at the first touch of the starter. Last set of Champions I ever bought. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#17 |
Thanks Geezer - that sounds so easy. I tend to over-think a problem and miss the simple stuff. Appreciate the help.
#18 |
Sounds like the distributor is off a tooth. Should be fine as long as the rotor points to the right wire at the right time.
#19 |
yes, rotate it til it lines up. The cap should have slots that it fits into so it only fits one way. On the caps that have the L shaped arms you rotate under the distributor, you MIGHT be able to install it at a different angle, but that would be a hack and a good way to have it not start next time you take the cap off.
#20 |
![]() Join Date: Dec 2013
It sure sounds like a worn / slack timing chain to me .Here's a quick 5 minute check to see whats really going on .
![]() https://www.youtube.com/watch?v=Aso_RXTHEB4
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#21 |
why do you suspect a slack timing chain? op stated he rotated the distributor without removing it and is trying to get it back to the right spot for initial timing. it was running before that.
#22 |
Just wanted to do a quick update and to thank everyone for their time/advice. Had family staying over Christmas (daughter from Ireland that I only see once a year) so didn't have any garage time.
I set the distributor as close as I could to it's former position using some photos I'd taken years ago. Didn't give it any gas and it started on the first crank. Didn't run well at all but it started. Seemed starved of gas as I really had to rev it to keep it running. I suspect I really had it flooded before. Had the timing light hooked up but then noticed a leaky lower rad hose. So, need to swap that out and then I'll get back to the starting issue. Big thanks for the help so far.
