weatherstrip adhesive remover
Hey Guys,
I am in california so I have no access to the weatherstrip adhesive remover that worked so well. Any ideas ? Have you used anything else? Paint is good so no grinding or sanding LOL. |
![]() Join Date: Oct 2014
Re: weatherstrip adhesive remover
Try a slow drying enamel reducer or a pre sanding cleaner. Surely you can find either of these in Cal. as body shops use these products.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
![]() Join Date: Dec 2013
Mineral spirits or NON ethanol gas.
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
For years I had used the 3M adhesive remover until I had one of our work trucks wrapped. He used denatured alcohol. Works better & a fraction of the cost.
Mineral spirits (Or at least the ca blend) does not work. I will try the other items listed above ! Thanks!
