Old 12-16-2018, 09:51 PM   #1
Ramiro0727
Rear gas tank
With all rear gas tanks. Do you always have to cut part part of the bed support rail. In order for the bed to fit correctly on the frame. Or is there other rear gas tanks thank you can purchase that you won’t have to cut it.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 12-17-2018, 12:44 AM   #2
WB72
Before and After
WB72's Avatar
Re: Rear gas tank
Pretty much all the blazer tanks need to have some of the bed support removed. About 2” between the frame rails should do the trick.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 12-17-2018, 01:14 AM   #3
Ramiro0727
Re: Rear gas tank
I knew I should of done it before we sprayed the bottom of the bed with bed liner. Unless I go with a different tank. Thanks WB72
Old 12-17-2018, 01:36 AM   #4
Ramiro0727
Re: Rear gas tank
Old 12-17-2018, 09:40 AM   #5
notsolo
notsolo's Avatar
Re: Rear gas tank
Boyd tanks fit without cutting any bed or frame supports......this under my 72 Blazer...C10 same...I can post long bed photo if you need it.
notsolo is offline   Reply With Quote
Old 12-17-2018, 10:39 AM   #6
Ramiro0727
Re: Rear gas tank
notsolo can you post more photos.
thanks,
Ramiro
Old 12-17-2018, 10:56 AM   #7
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: Rear gas tank
I like that!! How many gallons capacity is it? Maybe I will get one for my 67 GMC 3500 someday...?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 12-17-2018, 11:25 AM   #8
notsolo
notsolo's Avatar
Re: Rear gas tank
These are baffled aluminum tanks, about 17 gallons. Mine is a side fill...these photo's from 71 long bed, not using the efi on this 1. Tanks are set up either way, Spring shackle is right where the fill is, if your going lower you may want a top / bed fill....I have a brace on the rear cross member, from extra trailer hitch, nothing to do with the tank.
Old 12-17-2018, 12:34 PM   #9
rockyrivermark
Re: Rear gas tank
I installed a tank from this link
https://www.performanceonline.com/19...ank-19-gallon/
it was a aluminum tank with baffles, 19 gallon. under $439
fit great and no cutting required. THe best part for me was that the back of the tank was angled so you don't see the tank.
that's what I didn't like about the blazer tank or some others sold online, brothers trucks etc.
just have to remove bracket for spare tire.
hope this helps.
mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 12-18-2018, 01:25 AM   #10
Ramiro0727
Re: Rear gas tank
Thank you all for commenting . Some nice ideas to consider.
Old 12-18-2018, 08:41 AM   #11
Elliot949
Elliot949's Avatar
Re: Rear gas tank
Boyd's tanks fit like a glove...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 12-19-2018, 09:59 AM   #12
Old_Truck_Fan
Re: Rear gas tank
I used the LMC bed fill tank PN 32-5981. It's basically a blazer tank with a modified top so you don't have to cut into your bed supports. Cost was $150. I then installed an Aeromotive Phantom fuel pump for my LS swap. I think there is a YouTube video on Stacy David's Gearz on this tank's installation. But remember you have to cut a hole in the bed to fill it.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 12-19-2018, 03:21 PM   #13
Ramiro0727
Re: Rear gas tank
Old_Truck_Fan the tank I have looks like that one. Not sure if its from LMC. It came with the truck when we purchased it. Did you happen to measure the height of the tank?
thanks,
Ramiro
Old 12-19-2018, 12:11 PM   #14
rowdy11
Re: Rear gas tank
Old_Truck is the LMC tank baffled? I was looking at the same setup and fuel pump for my LS swap but was worried about pump starvation. I have a 4x4 so a bit more movement in the back than a 2X that I need to plan for.
Great thread!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 12-19-2018, 03:43 PM   #15
landarts
landarts
Re: Rear gas tank
Went with a Ford Mustang tank with 90 ohms sending unit from Tanks Inc., added a magnetic gas filler door from Yogi's, all welding in a smoothed out. Also changed out the standard cap for a no remove cap, just push the gas hose filler through the cap and fill. This fit with out any modifications to frame and the cost was reasonable.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-19-2018, 05:03 PM   #16
Old_Truck_Fan
Re: Rear gas tank
Great thread!
The LMC tank is not baffled. However, the Aeromotive Phantom pump has an internal "foam bucket" that surrounds the fuel pump inlet. It is meant for converting stock fuel tanks to EFI without adding baffles. Holley also makes a similar setup but uses their hydramat to pull from the bottom of the tank. If you are planning to have some slow moving off road fun then I agree pump starvation could be an issue at low fuel levels. The Holley setup might give you the best articulation performance but I don't have any direct experience with it. Their videos of it are pretty neat.
thanks,
Ramiro
I think it is around 12 inches from top to bottom which is right at the limit of the Aeromotive Phantom standard kit. (They have a longer pump arm available separately if needed.)
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-19-2018, 10:31 PM   #17
Lunnb
Re: Rear gas tank
I ordered a 1959 Impala tank from Amazon for about $90 . I made the brackets and straps from some scrap , bought some floor matting from TSC and glued to the straps to protect the tank . Moved the cross member and cut an opening for the filler neck . About 4 hours and done . I’ll pick up a flip down license plate bracket from the junk yard to complete the installation.
Lunnb is offline   Reply With Quote
Old 12-21-2018, 09:57 AM   #18
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Rear gas tank
How many gallons is this tank and how low does it hang? I currently have a 69 camaro tank in mine and it hangs really low.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 12-21-2018, 07:00 PM   #19
Lunnb
Re: Rear gas tank
The Impala tank is 29.25” x 27.75” x 7.25” so it doesn’t hang below the frame much at all . It’s a 16 gallon tank . I’m pretty happy with the way it turned out . Just waiting on the weather to improve so I can pickup a fold down license plate bracket and finish . I may have to shorten the fill neck an inch or so . Advance Auto had the same tank for about $100 delivered to the local store .
Old 12-19-2018, 11:32 PM   #20
burnin oil
Re: Rear gas tank
I put a 31 gallon late 70s blazer tank in my 72. It fit right in there without modding the bed. I modded the blazer crossmember and bolted that in for the rear support. Easy day with factory straps and skid plate. The hard part to all this is how to fill it. There are a million ways to accomplish this. I ended up cutting a hole in the bed and running the filler tube up the bedside next to the stake pocket. This allows me to still put gas in it when being used as a truck. Alot of slicker ways for the cruising crowd.
burnin oil is offline   Reply With Quote
Old 12-22-2018, 10:32 PM   #21
elf w/capital T
Re: Rear gas tank
Currently my 68 head the lmc side fill... had to notch the crossmember and the filler neck made it a tight tight fit for routing... also the filler kneck is small, so filling up takes a while, and it's not ready for EFI, having to do inline pump, just bought a boyd tank,
elf w/capital T is offline   Reply With Quote
Old 12-26-2018, 02:11 PM   #22
Firebird2077
Re: Rear gas tank
I did something different. 18 Gallon dune buggy tank. Has a site gauge to check the fuel though.
Firebird2077 is offline   Reply With Quote
