Old 11-21-2003, 01:28 PM   #1
GreenMystChevy
my exhaust smells bad
There's no such thing as a stupid question, just a stupid person. Well, here goes my question.
My exhaust, well, it smells. It has a very pungent odor that smells like gas and/ or something a little different. It's pretty strong.
Basically I was wondering how normal this is and what might be causing it. I know most of my other old vehicles don't smell quite that bad and I know that exhaust does have a smell to it, but something about this makes me think.
The only thing I can think of is the carb running too rich and running a lot of unburnt fuel through my pipes. I know nothing about tuning a carb and how to get the mixture right if that's the case though.
Thanks for the help guys.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 11-21-2003, 01:30 PM   #2
Moloko
Hoarding Rusty Objects
Moloko's Avatar
If it burns your nose, its probably running too rich. Try messing with the adjustment screws. Then them in to the right until the engine starts running rough, then back them off to the left until it idles smooth again. Do that to both mixture screws. Then re-adjust your idle so it idles at 800 or so RPM.
1985 Chevrolet K20 Silverado
1994 GMC Yukon
Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks
Moloko is offline   Reply With Quote
Old 11-21-2003, 01:33 PM   #3
bpmcgee
bpmcgee's Avatar
Moloko is right. Those are the idle mixture screws.
And, just for your information, there ARE stupid questions. For instance:
Do you walk to school or carry your lunch?
Brian
bpmcgee is offline   Reply With Quote
Old 11-21-2003, 01:36 PM   #4
Tim Rich
Re: my exhaust smells bad
I was thinking you might want to lay off the chili for a while...
Tim Rich
Kennesaw, GA
72 Stepside
65 Must@ng
Tim Rich is offline   Reply With Quote
Old 11-21-2003, 01:58 PM   #5
jcab
I need more money....
LOL
That is just about as funny as the reference to 'Socks on a duck' in another post.
You guys can always make me laugh!
whew.... I need some more coffee.....
Jay.
'68 LWB C10
'74 Duster ("It's not Rusted out, it's been modified for weight reduction")
'91 Civic
'97 Saturn
'88 Celica AWD turbo (R.I.P.) 273 hp Mustang Killer
jcab is offline   Reply With Quote
Old 11-21-2003, 03:43 PM   #6
gonebad2
Merciless Butcher
gonebad2's Avatar
If you have access to a real accurate tachometer (digital works best), hook it up. Adjust your idle mixture screws until you hit the highest RPM. Work the two screws together while you are trying to hit the high RPM. Once you've hit it, re-adjust your engine idle speed to around 800-850 rpm.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-21-2003, 03:44 PM   #7
GreenMystChevy
I walk to school and carry my lunch, am I weird
So are you guys thinking that the smell, the one from my truck, not me, is from it being too rich? Any other things that it could be? Would a weak spark also cause this? Anything else?
Thanks gonebad2- I will try to find a good tach somewhere, I've never heard of doing it that way.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 11-21-2003, 08:07 PM   #8
oldsub86
What kind of carb are you running? I am having the same issue with a 600 cfm Edelbrock carb. I have adjusted the screws several times as well as the float level etc. I think I may need to reduce the jet sizes in order to lean it out some. Anyone out there have a handle on this stuff? I would appreciate the advice too.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 11-21-2003, 08:18 PM   #9
lukecp
Formerly yellow72custom
lukecp's Avatar
I have found the most accurate and easiest way to adjus the idle mixutre on a carb is with a vaccum guage. I was able to get my truck idling much smoother when adjusting with the vaccum guage.
I just hooked up the guage, set the idle speed, and fiddled with the mixture screws until i got the highest possible vaccum at idle. Worked great!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-21-2015, 05:51 PM   #10
airbrushguy
Where do you hook the vacuum hose to?
airbrushguy is offline   Reply With Quote
Old 02-21-2015, 08:09 PM   #11
seattle gmc
seattle gmc's Avatar
Disconect the vacum line going to the brake booster (if you have one) and hook vacum gauge there.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 02-21-2015, 06:10 PM   #12
hamjet
hamjet's Avatar
Old thread, anywhere off the intake manifold thats drawing vacuum. Usually right under or off the carb plate.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
