11-21-2003, 02:20 PM | #1 |
1970 4X4 drive shaft
Does anyone know the exact specs on a drive shaft for a 1970 4X4 longbed 1/2 ton or does anyone have one that I can purchase.
11-21-2003, 05:12 PM | #2 |
weighs a ton. i want to say its 64 1/2 inches long slip not extended. ill check for you when i get home. this was on a 72 3/4 ton i had. the one i have is 5 or 6 inches in diameter. dont know if this helps at all since mines 3/4.
69k5 |
11-21-2003, 05:56 PM | #3 |
Resident Curmudgeon
1/2 and 3/4 on are the same except for ujoints. You can used them interchangeably if you buy "hybrid" ujoints.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-22-2003, 05:18 PM | #4 |
The specs I got from my local GM dealer said it was 49 13/16 inches long and 3 /12 inches in diameter. I didn't know if this was correct or not.
12-01-2003, 11:43 AM | #5 |
Does anyone else have any information?
