12-21-2018, 02:40 AM | #1 |
Where to get 350 small block 4 speed granny low shift stick
Shift stick recently snapped off an i had it welded back together. Where do i get another shifter that i can replace it just in case the weld , which was done very well, where should i start looking? Any ideas would be appreciated.
12-21-2018, 12:02 PM | #2 |
Re: Where to get 350 small block 4 speed granny low shift stick
The obvious places would be the parts board, Craigslist, FB pages, and swap meets. You can broaden your search by looking for more than just out of a 350 truck. They were all the same no matter which motor came in the truck.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-21-2018 at 12:13 PM. |
12-21-2018, 09:07 PM | #3 |
You want a shift lever for an SM465 [ or CH465]. First production year for this transmission was 1968. Also called a 4 Speed Muncie.
General Motors put them behind about every truck engine they had: L6s 250, 292, V8s 327, 350, 400, 396, 402, 427, 454, V6s 305, 351. Very tough tranny. You don't usually need the compound low "granny gear" but when you do, it's nice that it's there. The SM420 was its predecessor -- last year 1967. Slightly shorter case length, lower gears had even lower ranges than the 465. Gear #4 is 1:1 of course. SM is for SynchroMesh. No synchro in 1st.
12-21-2018, 09:22 PM | #4 |
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
12-22-2018, 01:18 AM | #5 | |
Yes, without pix, it could be anything.
12-22-2018, 04:39 PM | #6 |
Yeah I can do that but I don't know how to post pictures on this forum
12-22-2018, 05:00 PM | #7 |
Pretty sure I have one in the parts stash. Let me know if interested and I will dig it out and post a pic of it to the parts board. Stick only, no gear shift knob.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
12-30-2018, 06:04 AM | #8 |
This 350 as far as what I've been told by the owner, is out of 85 blazer
12-30-2018, 08:02 PM | #9 |
01-03-2019, 06:03 AM | #10 |
71 c10
12-22-2018, 05:11 PM | #11 |
Tino, click Post Reply, or if you hit Quick Reply, then hit Go Advanced. From there find Attach Files and hit Manage Attachments.
A side window will pop up with 5 boxes marked Choose File. Clicking on one will bring you to your saved pictures. [Select up to 5, but the fewer, the faster.] Select one or more, then hit Upload, once the white circle stops spinning, hit Close Window. If you can see an icon above Manage Attachments, hit Submit Reply, and that's it. Here's an SM465/T221 in the back of my Stepside. Not the best pic, but I needed to post a pic to see all the steps in the process.
12-23-2018, 06:54 PM | #12 |
yeah, definitely need to find out which trans you have , what year truck?
01-03-2019, 01:38 PM | #13 |
If you don't find a used one, take a look at Novak adapt. They have one that you can bend to suit your needs.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
01-03-2019, 01:54 PM | #14 |
I found the one I have, came from a Muncie SM265 out of a 71 2wd. Will get some pics taken of it and post to the parts forum and you take a look. Should be correct for your truck year for original look.
01-03-2019, 06:00 PM | #15 |
tino0217, posted the pics of the shift stick I have in the 67-72 parts forum section. You have first call if interested.
