Temperature sensor wire reroute
I have a 68 with the stock 307. I am getting ready to pull the motor so i can swap in a 350 that i am rebuilding. Currently the temp sensor wire for the gauge runs along the intake and is clipped to the factory valve covers. I don't plan on reusing the valve covers. How are people routing the temp sensor wire? I would think you would not want it just laying on the intake unsecured. Thanks!
#2 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Temperature sensor wire reroute
You can also run it down the left side of the block and clamp it to an oil pan bolt and run it to the back of the engine and over to the block.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Do you have a picture showing where this wire comes from or its color? Wiring mine now and don't know where or which wire is the temp. Thanks
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#4 | |
Msgt USAF Ret
Here is one showing the temperature sender but it is a mechanical sender and does not go to the dash gauges. It shows how the wire could be routed over to the frame rail and back to the firewall.
![]() Join Date: May 2010
The green temperature wire was originally enclosed in a small (1/4"?) fabric loom from the plastic harness conduit attached to the firewall. The loom was then clipped to the intake side of the left valve cover as described in post #1. At the front of the valve cover it dropped down to a clip attached to a threaded stud/bolt at the bottom of the water pump. The wire then ran rearward to the temperature sender.
I am also using valve covers without the clips and have the fabric wire loom lying on the intake side lip of the valve cover. So far, the wire has not changed position. I suspect that may be due to the rigidity added by the loom and the clip at the water pump. The best pictures I have are attached. However, note in the second picture that I had the front clip and stud in the wrong position on the water pump. In the proper location, the clip would also have a more horizontal orientation. |
Thanks for the help everyone. My wire loom is extremely greasy(just like the engine). Is it worth replacing? Below are pictures for reference. Ignore the mouse poop on the intake. That stuff gets everywhere!
