oil spray
ive got an edelbrock intake w the oil filler tube in ive got oil spray all over the intake . i bought a new pcv valve still spray i know my carb needs rebuilt. my stock carb im waiting to rebuild my holley
5-7 dropped 87 CC Dually
Could use a little more info here. Power wash the motor and tell us where it is coming from.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
its coming out of the filler tube
Insert witty comment here
The only reason it would be coming out of the Filler tube that I know of is,
1. You don't have a baffel in you valve cover. ( If this just started then that is most likely not the issue.) 2. Ventalation of you crankcase is not working properly. If you relplaced you PCV valve the you need to check to see if the vacume is it hooked up and working. Vacume lines cracked or disconnected? Is it hooked up to the right port? I'm not sure if this is the prob but I would start there.
So many trucks, So little time! |
Do you have a breather on the other valve cover?
when i dropped the engine in i bought new lines tried differnt ports its been doing from day one
i was going to attach pix but i cant
I'm leaving to go hunting. You can send it to me. I'll look at it when I get back. toynova@aol.com
I rather be in my 77 Sanger Picklefork Jet Hydro! Last edited by toytruck; 11-22-2003 at 09:18 PM. |
I got the pic but I can't post it either. In this reply form is says that I may not post attachments- Smilies are on. Funny I could yesterday.
motor pic
